Hi, i doing coding with nrf24l01 and i got issue where a function-definition is not allowed here before ‘{’ token at
BLYNK_WRITE(V1) {
and
BLYNK_WRITE(V2) {
can anyone help me to find the problem? im already looking for clue in provious topic but it didnt help
here’s my code to be exact
#define BLYNK_PRINT Serial//code_receiverv4_nrf24L01 | Arduino IDE 2.3.2
#define BLYNK_TEMPLATE_ID "TMPL65QkzPU9S"
#define BLYNK_TEMPLATE_NAME "WSN lamp"
#define BLYNK_AUTH_TOKEN "27CEcwlLSJ_02flZjsWpkBr1NiFhUV-D"
#include <RF24.h>
#include <nRF24L01.h>
char ssid[] = "realme X";
char pass[] = "jeruk123";
//#define CE_PIN 8
//#define CSN_PIN 7
const byte addresses [][6] = {"00001", "00002"}; // Define the transmit pipe
typedef struct
//int DevID;
// float DevVal;
// int DevSig;
float Voltage; //ta
float Value; //ta
} SensorData;
SensorData sensorNode;
RF24 radio(D0, D8); // Create a Radio
Serial.println("Nrf24L01 Receiver Starting");
radio.begin();
radio.openWritingPipe(addresses[1]); //Setting the address at which we will send the data
radio.openReadingPipe(1, addresses[0]); //Setting the address at which we will receive the data
if (radio.available())
BLYNK_WRITE(V1) {
LED = param.asInt();
radio.write(&LED, sizeof(LED));
BLYNK_WRITE(V2) {
Auto = param.asInt();
radio.write(&Auto, sizeof(Auto));
radio.read(&sensorNode, sizeof(sensorNode));
Blynk.virtualWrite(V0, "sensorNode.Value");
Serial.print(", Value=");
Serial.print(sensorNode.Value);
Serial.print(", Voltage=");
Serial.println(sensorNode.Voltage);
// Serial.print("Received: DevID=");
// Serial.print(sensorNode.DevID);
// Serial.print(", DevVal=");
// Serial.print(sensorNode.DevVal);
// Serial.print(", DevSig=");
// Serial.print(sensorNode.DevSig);
// If no data available, you might want to add a delay or other logic
// to prevent busy-waiting, depending on your application requirements.
delay(100); // Example delay to prevent excessive looping
