Hi, sorry for my title but I’m going crazy for this:
I create a system that measure instantly by INA219, power generated from my solar panel. So, all data I can visualize on my phone with graphic ecc ecc and I can active my 2 relay (relay is not important beacuse don’t change the code, Blynk provide to set button on relay), that active 2 lights.
According for this, I have two version of my code. If you read my first version, I’m sure you won’t like this, but it’s is only version without problems!
This is my first version:
#include <Blynk.h>
#include <Wire.h>
#include <Adafruit_INA219.h>
char auth[] = "++++++";
Adafruit_INA219 ina219;
char ssid[] = "****";
char pass[] = "****";
float shuntvoltage = 0;
float busvoltage = 0;
float current_mA = 0;
float loadvoltage = 0;
float power_mW = 0;
float energy = 0;
unsigned long interval = 100;
unsigned long currentMillis = 0;
#define greenLED D7
#define redLED D8
void setup(void) {
pinMode(greenLED, OUTPUT);
pinMode(redLED, OUTPUT);
while (!Serial) {
delay(1);
uint32_t currentFrequency;
ina219.begin();
void loop(void){
if(Blynk.connected()){
digitalWrite(greenLED, HIGH);
digitalWrite(redLED, LOW);
currentMillis = millis();
if (currentMillis - previousMillis >= interval){
ina219values();
// stampaValori();
}else{
digitalWrite(greenLED, LOW);
digitalWrite(redLED, HIGH);
void ina219values() {
shuntvoltage = ina219.getShuntVoltage_mV();
busvoltage = ina219.getBusVoltage_V();
current_mA = ina219.getCurrent_mA();
if (current_mA<0){
current_mA = current_mA*(-1);
power_mW = ina219.getPower_mW();
loadvoltage = busvoltage + (shuntvoltage / 1000);
energy = energy + loadvoltage * current_mA / 3600;
void stampaValori(){
Serial.print("Bus Voltage: "); Serial.print(busvoltage); Serial.println(" V");
Serial.print("Shunt Voltage: "); Serial.print(shuntvoltage); Serial.println(" mV");
Serial.print("Load Voltage: "); Serial.print(loadvoltage); Serial.println(" V");
Serial.print("Current: "); Serial.print(current_mA); Serial.println(" mA");
Serial.print("Power: "); Serial.print(power_mW); Serial.println(" mW");
Serial.print("Energia: "); Serial.print(energy); Serial.println(" mWh");
Serial.println("");
void myTimerEvent(){
Blynk.virtualWrite(V4, current_mA / 1000);
Blynk.virtualWrite(V5, power_mW / 1000);
Blynk.virtualWrite(V6, energy / 1000);
If you read, surely you will not agree to 1)delay 2)Blynk.begin on reconnect 3)loop not clean ecc ecc.
But this version, I repeat is a bomb! Never disconnection and nothing problem!
After this, I wanted to evolve my version, cleaning loop, setting method to provide connection and manage two timer of my two lights. The result is this: In this code you can read setting of 4 button with 4 timer, because my set relay is composid of 4 parts and I set just know for future illumination:
#include <Blynk.h>
#include <Wire.h>
char ssid[] = "++++++++++";
char pass[] = "++++++++++";
float current_h = 0;
float current_day = 0;
float power_mW = 0;
float energy = 0;
boolean isFirstConnect = true;
boolean isConnesso;
#define relayFaretto10WD4 D4
#define relayMadonnaD5 D5
#define relayD9 D9
#define relayD10 D10
#define greenLEDD7 D7
#define redLEDD8 D8
#define buttonFaretto10W V0 // >> D4
#define buttonMadonna V1 // >> D5
#define buttonD9 V2 // >> D9
#define buttonD10 V3 // >> D10
#define correnteIstantanea V4
#define potenzaIstantanea V5
#define energiaTotale V6
#define correnteTotale V7
#define correnteTotaleDay V8
void setup(void) {
pinMode(greenLEDD7, OUTPUT);
pinMode(redLEDD8, OUTPUT);
timer.setInterval(1000L, letturaPannello);
ina219.begin();
void loop(void){
void letturaPannello(){
isConnesso = controllaConnessione();
if(isConnesso){
ina219values(); // LEGGO IL SENSORE
sendIna219Values();
//stampaValori();
}else{
Blynk.connect();
//delay(1000);
boolean controllaConnessione(){
digitalWrite(greenLEDD7, HIGH);
digitalWrite(redLEDD8, LOW);
return true;
}else{
digitalWrite(greenLEDD7, LOW);
digitalWrite(redLEDD8, HIGH);
return false;
current_mA = abs(ina219.getCurrent_mA());
energy = energy + loadvoltage * current_mA / 3600; // conteggio energia totale
current_h = current_h + current_mA / 3600; // conteggio corrente totale
current_day = current_day + current_mA / 3600; // conteggio corrente giornaliero
void sendIna219Values(){
Blynk.virtualWrite(correnteIstantanea, current_mA / 1000); // VIRTUAL PIN V4
Blynk.virtualWrite(potenzaIstantanea, power_mW / 1000); // VIRTUAL PIN V5
Blynk.virtualWrite(energiaTotale, energy / 1000); // VIRTUAL PIN V6
Blynk.virtualWrite(correnteTotale, current_h / 1000); // VIRTUAL PIN V7
Blynk.virtualWrite(correnteTotaleDay, current_day / 1000); // VIRTUAL PIN V8
BLYNK_CONNECTED() {
if (isFirstConnect) {
Blynk.syncVirtual(buttonFaretto10W, buttonMadonna, correnteIstantanea, potenzaIstantanea, energiaTotale, correnteTotale, correnteTotaleDay, V9, V10, V11, V12); //V9 V10 V11 V12 sono TIMER
isFirstConnect = false;
BLYNK_WRITE(buttonFaretto10W){ //controllo VIRTUAL Button Faretto
if(param.asInt()==1){
digitalWrite(relayFaretto10WD4, HIGH); // START RELAY FARETTO
}else{
digitalWrite(relayFaretto10WD4, LOW); // STOP RELAY FARETTO
BLYNK_WRITE(buttonMadonna){ //controllo VIRTUAL Button Madonna
digitalWrite(relayMadonnaD5, HIGH); // START RELAY MADONNA
}else{
digitalWrite(relayMadonnaD5, LOW); // STOP RELAY MADONNA
BLYNK_WRITE(V9){ //controllo Timer Faretto
Blynk.virtualWrite(buttonFaretto10W, 1); // START RELAY FARETTO
//digitalWrite(relayFaretto10WD4, HIGH);
}else{
Blynk.virtualWrite(buttonFaretto10W, 0); // STOP RELAY FARETTO
//digitalWrite(relayFaretto10WD4, LOW);
current_day = 0;
BLYNK_WRITE(V10){ //controllo Timer Madonna
Blynk.virtualWrite(buttonMadonna, 1); // START RELAY MADONNA
//digitalWrite(relayMadonnaD5, HIGH);
}else{
Blynk.virtualWrite(buttonMadonna, 0); // STOP RELAY MADONNA
//digitalWrite(relayMadonnaD5, LOW);
current_day = 0;
//////7//////////////////////////////////////////////////////////////////////////////////
///////////////////////CONTROLLO RELAY D9 e D10 CHE NON HAI ANCORA CONNESSO AL NODEMCU
BLYNK_WRITE(buttonD9){ //controllo VIRTUAL Button D9
digitalWrite(relayD9, HIGH); // START RELAY D9
}else{
digitalWrite(relayD9, LOW); // STOP RELAY D9
BLYNK_WRITE(buttonD10){ //controllo Button D10
digitalWrite(relayD10, HIGH); // START RELAY D10
}else{
digitalWrite(relayD10, LOW); // STOP RELAY D10
BLYNK_WRITE(V11){ //controllo Timer D9
Blynk.virtualWrite(buttonD9, 1);
//digitalWrite(relayD9, HIGH); // START RELAY D9
}else{
Blynk.virtualWrite(buttonD9, 0);
//digitalWrite(relayD9, LOW); // STOP RELAY D9
BLYNK_WRITE(V12){ //controllo Timer D10
Blynk.virtualWrite(buttonD10, 1);
//digitalWrite(relayD10, HIGH); // START RELAY D10
}else{
Blynk.virtualWrite(buttonD10, 0);
//digitalWrite(relayD10, LOW); // STOP RELAY D10
Serial.print("CorrenteH: "); Serial.print(current_h); Serial.println(" mAh");
Serial.print("CorrenteHDay: "); Serial.print(current_day); Serial.println(" mAh");
Serial.println("");
This version doesn’t work correctly! Blynk bans me everytime!I clean loop and I order the cose so what I wrong?
Thank you for spending time for me.
Best regards
