Hi
I was wondering if it is possible to set formatting options for float numbers (/pin.#/°C) from hardware,
something like Blynk.setProperty(V1,“format”,"/pin.#/°C");
If yes, what is the required syntax
What about HTTP RESTful api
Yes, but it has nothing to do with Blynk per se… Just Arduino code that works with Serial.print() and String()
It works just as well with Blynk.virtualWrite()
int temperature = bme.readTemperature(); // get raw temperature value (normally displayed to three decimal points)
Blynk.virtualWrite(V0, String(temperature, 1) + " C"); // Display with only one decimal point and add in the C
Bear in mind if you send a String + “C” to the Virtual Pin it won’t Log/graph
Thanks!
Log/graph is a prerequisite in my case.
So, i guess i shall pass it to the wishlists
Good point @ldb
But as Blynk sends all virtual pin data as strings anyhow, I figured out that ‘pre formatting’ the string (numbers only) will allow proper (and confirmed as graphable) decimal formatting at least.
char temperature[4];
dtostrf(bme.readTemperature(), 3, 1, temperature);
Blynk.virtualWrite(V0, temperature);
Learned something today, didn’t know dtostrf but I think the String method would work but without “C”
Silly me… I never even tried ![]()
EDIT - Yep, works just fine on the SuperChart… and simpler too ![]()
Blynk.virtualWrite(V0, String(temperature, 1));
Just use this in the widget /pin/ °C
