Hello. I am new on this kind of projects. I need to fix more than one time input in my app for my sonoff but I cannot find how to do it. Can soneone help me?
Thks for your reply. I already did but the problem is when I fix the time for one of them, then other time input is also updated whit the same time. I cannot fix different times for each time input.
OK, then use different vPins with different BLYNK_WRITE()
functions to collect the parameters, then send that to a common function for the actual code processing… same concept as having the same variable updated by different sensors at different times, etc.
Thks for your reply but I cannot do that from the iOS app.
This is mine. I don’t know how to link different V’s to same button+led
Each vPin will have its own BLYNK_WRITE()
function, but in that function you can just apply the Time Input parameters to global variables that then do your thing from another void doStuff()
function in one of a few different ways…at this point it comes down to Arduino programming and is not a Blynk specific thing.
input = Timer 1 param
input = Timer 2 param
if input == 1 do something
Or if kept as separate variables then use comparison logic.
input1 = Timer 1 param
input2 = Timer 2 param
if input1 |or| input2 == 1 do something
Or whatever other methods you need.
