HI,
I’ve been trying to send data from the Firebeetle 8266 board and BME sensor and I’m getting the classic “%.3f” value in my sensor display…
The value prints to serial fine and can be seen in sm…?
Heres my code.
Just because you’ve done a fresh install of the IDE it doesn’t necessarily mean that you’ve installed the latest Blynk library and ESP core.
With the ESP core it really depends on which URL you’ve used.
Starting with 1.6.4, Arduino allows installation of third-party platform packages using Boards Manager. We have packages available for Windows, Mac OS, and Linux (32 and 64 bit).
Install the current upstream Arduino IDE at the 1.8.7 level or later. The current version is on the Arduino website.
Start Arduino and open the Preferences window.
Enter https://arduino.esp8266.com/stable/package_esp8266com_index.json into the Additional Board Manager URLs field. You can add multiple URLs, separating them with commas.
Open Boards Manager from Tools > Board menu and install esp8266 platform (and don’t forget to select your ESP8266 board from Tools > Board menu after installation).
Your timer call-back is already set for two seconds… not sure why you have all the delays throughout your code? I would remove all four of the delays(xxx) as well as the bme.update() call in the loop. What is being printed in the Serial output?
I have no idea to be honest, my coding skills basically equate to lego… I take bits from other code and see if it works lol
I’m just trying to get the values out of this https://www.dfrobot.com/product-1697.html
into a nice looking UI that Blynk offers. I’ve only managed to get the temp value working so far!
Heres the wiki if you have any idea?
Pete, I do know exactly what that means thank you.
A word of advice…drop the dam attitude! You type your messages like you’ve got a massive chip on your shoulder. I’d rather have no help than somone being a know it all douche!
Thank you for that ’advice’. I think I’ll opt for the “no help” option from now on.
A word of caution though… As this “know it all douche” comment was aimed at me, I won’t take any action. But, if you repeat this, or make similar comments towards other community members then I will suspend your account. Please consider this to be your one and only warning on this issue.
