I bought new board as attached and I want to set its type in IED software but couldn’t know the right name for it.
I used WeMos D1 R1 and load the blink example for Node MCU and ESP8266_ standalon but i got this error below and the Blynk app show it is not online.
((Arduino: 1.8.5 (Windows 7), Board: “WeMos D1 R1, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 115200”
Build options changed, rebuilding all
Executable segment sizes:
IROM : 247828 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 27928 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs…)
DATA : 1308 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 2220 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 25544 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 279284 bytes (26%) of program storage space. Maximum is 1044464 bytes.
Global variables use 29072 bytes (35%) of dynamic memory, leaving 52848 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.8
Serial port COM7
Traceback (most recent call last):
File “C:\Users\Mustafa\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.3/tools/upload.py”, line 65, in
esptool.main(cmdline)
File “C:/Users/Mustafa/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/esptool\esptool.py”, line 2889, in main
esp = chip_class(each_port, initial_baud, args.trace)
File “C:/Users/Mustafa/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/esptool\esptool.py”, line 237, in init
self. port = serial.serial_for_url(port)
File “C:/Users/Mustafa/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/pyserial\serial_ init .py”, line 88, in serial_for_url
instance.open()
File “C:/Users/Mustafa/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/pyserial\serial\serialwin32.py”, line 78, in open
self._reconfigure_port()
File “C:/Users/Mustafa/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.3/tools/pyserial\serial\serialwin32.py”, line 222, in _reconfigure_port
‘Original message: {!r}’.format(ctypes.WinError()))
serial.serialutil.SerialException: Cannot configure port, something went wrong. Original message: PermissionError(13, ‘A device attached to the system is not functioning.’, None, 31)
“Show verbose output during compilation”
option enabled in File -> Preferences.))
where is problem please ??
