Hi Blynk folks, thanks for creating a really smashing IoT platform which I only just discovered and am eager to dig into! However, I am considering integration with the existing custom built data acquisition/logging/display/control framework we use for engineering teaching/research, and the capabilities of file export/import seem a bit unclear to me. I am sorry if I am asking the obvious here, but I would really like to have a good overview of options available, preferrably for programmatic control of reading/writing small text or binary files at regular, short intervals. My interpretation after (shallowly) reading a couple of other threads is that it is no longer possible to do this with a locally hosted Blynk server. Is that correct? Another option mentioned is the use of a PostgreSQL DB for storage, but looking at the schema ( https://raw.githubusercontent.com/blynkkk/blynk-server/master/server/core/src/main/resources/create_schema.sql ) it seems pretty involved. Is there any documentation relating to that?
Kind regards,
Daniel
