hello Everyone
kindly Assist I have been trying DHT11 using Wemos D1 R1 but the serial monitor keeps indicating Failed to read from DHT sensor
i got the code from example.blynk.cc
code
#include <DHT.h>
char auth[] = " "; //Enter the Auth code which was send by Blink
char ssid[] = ""; //Enter your WIFI Name
char pass[] = ""; //Enter your WIFI Password
#define DHTPIN 2 // Digital pin 2
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h); //V5 is for Humidity
Blynk.virtualWrite(V6, t); //V6 is for Temperature
dht.begin();
