I am running Blynk v1.3.2 on an ESP32 and using the esp_camera library in the Arduino IDE. In the application, I am doing a frame grab off the camera and encoding it in base64. Whenever the camera code is enabled, I get the “Secure connection failed” error from Blynk. Without the camera enabled, Blynk connects and data is sent correctly. I would also note the following in the console log at startup:
E (3502) gpio: gpio_install_isr_service(449): GPIO isr service already installed
I have looked through the forum and found successful cases of camera capture on the ESP32 with Blynk, but can not seem to nail down this issue. The code and console log are below. Could this be an ISR issue between Blynk and the esp_camera library?
Thanks!
//-- DEFINES ------------------------------------------------------------------
//-- Blynk IoT ----------------------------------------------------------------
/* Fill in information from your Blynk Template here */
/* Read more: https://bit.ly/BlynkInject */
#define BLYNK_TEMPLATE_ID "<MY_ID>"
#define BLYNK_TEMPLATE_NAME "<MY_NAME"
#define BLYNK_FIRMWARE_VERSION "0.1.13"
#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
#define ENABLE_CAM
#define USE_ESP32_DEV_MODULE
//-- Camera -------------------------------------------------------------------
#define CAMERA_MODEL_M5STACK_ESP32CAM // No PSRAM
//-- INCLUDES -----------------------------------------------------------------
#ifdef ENABLE_CAM
// Camera
#include "esp_camera.h"
#include "camera_index.h"
#include "camera_pins.h"
#include <base64.h>
#include <libb64/cencode.h>
#endif
// Blynk IoT Service
#include "BlynkEdgent.h"
//-- GLOBALS- -----------------------------------------------------------------
BlynkTimer timerBlynk;
//-- Function Definitions -----------------------------------------------------
//-- Timer Callback -----------------------------------------------------------
void timerCallback()
int valD = 0;
float valC = 0.0;
float valT = 0.0;
float valH = 0.0;
float valP = 0.0;
int valPV = 0;
int valPC = 0;
float valPP = 0;
#ifdef ENABLE_CAM
// Camera Variables
camera_fb_t *fb = NULL;
esp_err_t res = ESP_OK;
// Read Camera
fb = esp_camera_fb_get();
delay(100);
if (!fb)
Serial.println("Camera capture failed");
ESP.restart();
BLYNK_LOG("[APP] ESP HEAP: %d", ESP.getFreeHeap());
BLYNK_LOG("[APP] ESP IMAGE:");
String base64image = base64::encode(fb->buf, fb->len);
Serial.println(base64image);
esp_camera_fb_return(fb);
#endif
// Bundle the data into a group with a single timestamp
Blynk.beginGroup();
Blynk.virtualWrite(V0, valD);
Blynk.virtualWrite(V1, valC);
Blynk.virtualWrite(V2, valT);
Blynk.virtualWrite(V3, valH);
Blynk.virtualWrite(V4, valP);
Blynk.virtualWrite(V5, valPV);
Blynk.virtualWrite(V6, valPC);
Blynk.virtualWrite(V7, valPP);
Blynk.endGroup();
// Print to Serial Log
BLYNK_LOG("[APP] DATA: %.1f %d %.1f %.1f %.1f %d %d %.1f", valC, valD, valT, valH, valP, valPV, valPC, valPP);
//-- SETUP --------------------------------------------------------------------
//-- Config GPIO -----------------------------------------------------------
pinMode(LED_BUILTIN, OUTPUT);
// Flash LED
digitalWrite(LED_BUILTIN, HIGH);
delay(300);
digitalWrite(LED_BUILTIN, LOW);
delay(300);
//-- Init I2C Bus -----------------------------------------------------------
//Wire.begin();
//-- Init Debug Serial Port -------------------------------------------------
delay(100);
BLYNK_LOG("[APP] LOG Serial UP");
#ifdef ENABLE_CAM
//-- Startup Camera ---------------------------------------------------------
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sccb_sda = SIOD_GPIO_NUM;
config.pin_sccb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.frame_size = FRAMESIZE_VGA;
config.pixel_format = PIXFORMAT_JPEG;
config.grab_mode = CAMERA_GRAB_WHEN_EMPTY;
config.fb_location = CAMERA_FB_IN_DRAM;
config.jpeg_quality = 12;
config.fb_count = 1;
// Camera Init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
BLYNK_LOG("[APP] Camera init failed with error 0x%x\n", err);
ESP.restart();
BLYNK_LOG("[APP] Camera UP");
// Read Camera
delay(100);
if (!fb)
BLYNK_LOG("Camera capture failed");
ESP.restart();
#endif
//-- Blynk.io ---------------------------------------------------------------
BlynkEdgent.begin();
//-- Data Polling timerBlynk ------------------------------------------------
// Setup a function to be called every 5 seconds
timerBlynk.setInterval(5000L, timerCallback);
//-- MAIN LOOP ----------------------------------------------------------------
//-- Blynk.io Handler -------------------------------------------------------
BlynkEdgent.run();
timerBlynk.run(); // Initiates Blynktimer
From the console:
[748] [APP] LOG Serial UP
[1542] [APP] Camera UP
[1777] [APP] ESP HEAP: 147364
[1777] [APP] ESP IMAGE:
<BASE64_DATA_STRING_HERE>
[3531]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
///_, /////_
/__/ v1.3.2 on ESP32#StandWithUkraine StandWithUkraine | #StandWithUkraine banner and related documents
Device: Blynk <DEV_NAME>
Firmware: 0.1.13 (build Jan 29 2024 19:05:48)
Token: G6O6 - •••• - •••• - ••••
Platform: ESP32 @ 240MHz
Chip rev: 3
SDK: v4.4.5
Flash: 16384K
Free mem: 98404[3573] INIT => CONNECTING_NET
[3584] Connecting to WiFi: <MY_SSID>
[4992] Using Dynamic IP: 192.168.12.229
[4992] CONNECTING_NET => CONNECTING_CLOUD
[5002] Connecting to blynk.cloud:443
[5536] Secure connection failed
[10006] Connecting to blynk.cloud:443
[10451] Secure connection failed
50060] Connecting to blynk.cloud:443
[50387] Secure connection failed
[54998] Timeout
[55099] [APP] ESP HEAP: 95764
[55099] [APP] ESP IMAGE:
56661] [APP] DATA: 0.0 0 0.0 0.0 0.0 0 0 0.0
[56681] Connecting to blynk.cloud:443
[57043] Secure connection failed
