Hello everyone,
as part of a larger project I am trying to get an LED to fade in and out when a virtual pin is toggled on, and then turn off when the virtual pin is off. I have several codes that work outside of blynk, meaning that i can use each one as a standalone code to get the LED to fade the way i want it, but when i try to import the code into my blynk project i get nothing. Obviously i am missing something, but after days and several approaches, i am yet to see what that is. Can anyone point me in the right direction?
Thanks!
#define BLYNK_TEMPLATE_ID ""
#define BLYNK_TEMPLATE_NAME ""
#define BLYNK_AUTH_TOKEN ""
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32_SSL.h>
char ssid[] = "";
char pass[] = "";
int blinkLed=0;
unsigned long UnlockCheckM;
unsigned long LockCheckM;
unsigned long proximityM =0;
int proximityCounter=0;
int bck = 18;
int fwd = 5;
int pirsensor=25;
int bckswtch=32;
int fwdswtch=33;
int chrgprt=2;
int light = 19;
int chargelvl;
int blink = 13;
int emglock=35;
double lon=;
double lat=;
BLYNK_WRITE(V0){
if(param.asInt()==1){
digitalWrite(chrgprt,HIGH);
Blynk.setProperty(V0, "url", 1);
Blynk.setProperty(V11, "isHidden", false);
digitalWrite(chrgprt,LOW);
Blynk.setProperty(V0, "url", 0);
Blynk.setProperty(V11, "isHidden", true);
BLYNK_WRITE(V1){
digitalWrite(light,HIGH);
blinkLed=0;
Blynk.virtualWrite(V7,0);
digitalWrite(blink,LOW);
digitalWrite(light,LOW);
BLYNK_WRITE(V4){
digitalWrite(fwd,HIGH);
LockCheckM=millis();
Blynk.setProperty(V5,"isDisabled",true);
digitalWrite(fwd,LOW);
Blynk.setProperty(V5,"isDisabled",false);
BLYNK_WRITE(V5){
digitalWrite(bck,HIGH);
UnlockCheckM=millis();
Blynk.setProperty(V4,"isDisabled",true);
digitalWrite(bck,LOW);
Blynk.setProperty(V4,"isDisabled",false);
BLYNK_WRITE(V7){
int blinkLed= param.asInt();
BLYNK_WRITE(V11){
void lockSafety()
if(digitalRead(fwdswtch)==LOW){
Blynk.virtualWrite(V6,0);
} else if (digitalRead(fwdswtch)==HIGH){
Blynk.virtualWrite(V6,1);
Blynk.virtualWrite(V4,0);
void unlockSafety()
if(digitalRead(bckswtch)==LOW){
Blynk.virtualWrite(V2,0);
} else if (digitalRead(bckswtch)==HIGH){
Blynk.virtualWrite(V2,1);
Blynk.virtualWrite(V5,0);
void gauge()
int ldrVal=analogRead(chargelvl);
Blynk.virtualWrite(V3,ldrVal);
void failSafeUnlock(){
if(millis()-UnlockCheckM>=4000 && digitalRead(bck)==HIGH){
void failSafeLock(){
if(millis()-LockCheckM>=4000 && digitalRead(fwd)==HIGH){
void blink_led()
if(blinkLed == 1){
int time = millis();
value = 128+127*cos(2*PI/10000*time);
analogWrite(blink, value);
}else{
analogWrite(blink,LOW)
void proximity(){
if (digitalRead(fwdswtch)==HIGH && digitalRead(pirsensor)==LOW && proximityCounter==0){
proximityM=millis();
proximityCounter ++;
Serial.println(proximityCounter);
}else if (digitalRead(fwdswtch)==HIGH && digitalRead(pirsensor)==LOW){
proximityCounter=0;
void proximityEvent(){
if(proximityCounter==4 && millis()-proximityM <= 4000){
Blynk.logEvent("proximity");
Blynk.virtualWrite(V9,1);
proximityCounter=0;
}else{
Blynk.virtualWrite(V9,0);
void gmap(){
Blynk.virtualWrite(V10,lon,lat);
void emergencylock() {
if(digitalRead(emglock)==LOW){
timer.setInterval(100L, lockSafety);
timer.setInterval(100L, unlockSafety);
timer.setInterval(60000L,gauge);
timer.setInterval(50L,blink_led);
timer.setInterval(100L,failSafeUnlock);
timer.setInterval(100L,failSafeLock);
timer.setInterval(800L,proximity);
timer.setInterval(100L,proximityEvent);
timer.setInterval(60000L,gmap);
timer.setInterval(100L,emergencylock);
//timer.setInterval(1000L,safetyBlink);
pinMode(fwd,OUTPUT);
pinMode(bck,OUTPUT);
pinMode(chrgprt,OUTPUT);
pinMode(light,OUTPUT);
pinMode(blink,OUTPUT);
pinMode(chargelvl,INPUT);
pinMode(emglock,INPUT_PULLUP);
pinMode(bckswtch,INPUT_PULLUP);
pinMode(fwdswtch,INPUT_PULLUP);
pinMode(pirsensor,INPUT_PULLUP);
Specifically, the function i am using to try and get this to work is blink_led(), connected to virtual pin 7.
The pwm pin i am using for the LED is pin number 13.
Thank you in advance!
