Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Node MCU
• Smartphone ANDROID (6.0.1 MMB29M)
• Blynk server
• Blynk_Release_v0.4.4
• Add your sketch code.
Code should be formatted as example below.
http://twitter.com/blynk_app
This example runs directly on ESP8266 chip.
Please be sure to select the right ESP8266 module
in the Tools -> Board menu!
int UP=0;
int DOWN=12;
int cutoff_temp=40;
int relay=14;
int MOD=16;
int SW=4;
int a,da,up,down,mod,sw;
char auth[] = "**************";
char ssid[] = "****";
char pass[] = "********";
pinMode(UP,INPUT);
pinMode(DOWN,INPUT);
pinMode(A0,INPUT);
pinMode(relay,OUTPUT);
pinMode(MOD,INPUT);
pinMode(SW,INPUT);
digitalWrite(UP,LOW);
digitalWrite(DOWN,LOW);
digitalWrite(MOD,LOW);
digitalWrite(SW,LOW);
digitalWrite(relay,LOW);
mod=digitalRead(MOD);
if(mod==LOW)
a= analogRead(A0);
da= (a-574.8)/6.13;
up= digitalRead(UP);
down= digitalRead(DOWN);
auto_mode();
set_temp();
Blynk.virtualWrite(1,da);
Blynk.virtualWrite(2,cutoff_temp);
if(mod==LOW)
a= analogRead(A0);
da= (a-574.8)/6.13;
sw=digitalRead(SW);
manual_mode();
set_temp();
void auto_mode()
if(da>cutoff_temp)
digitalWrite(relay,HIGH);
WidgetLED led1(V3);
WidgetLED led2(V4);
led1.on();
led2.off();
else if(da<=cutoff_temp-5)
WidgetLED led1(V3);
WidgetLED led2(V4);
led1.off();
led2.on();
void manual_mode()
if(sw==HIGH)
WidgetLED led1(V3);
WidgetLED led2(V4);
led1.on();
led2.off();
//else if(sw==LOW)
// digitalWrite(relay,LOW);
// WidgetLED led1(V3);
// WidgetLED led2(V4);
// led1.off();
// led2.on();
else if(da>cutoff_temp)
WidgetLED led1(V3);
WidgetLED led2(V4);
led1.off();
led2.on();
void set_temp()
if(up==HIGH)
cutoff_temp++;
else if(down==HIGH)
cutoff_temp--;
