Hi Blynkers,
can Blynk create export of template settings to file and import from file?
You shouldn’t worry about this, everything stored in the cloud so if you lost your phone or accidentally format it all you have to do is install blynk IOT app and sign in using your blynk account and you should see everything is the same, all data, configuration, widgets, etc…
I think his mean is QR clone project same Blynk legacy
he mentioned export to file, he didn’t mention QR code
I could save my settings before changing the template, it is also possible to submit the settings to the forum for discussion, rather than just a sketch.
Yes. this will be done soon.
maybe if i know the template ID and Token can i recover it? The second time in a week, I accidentally deleted everything
