Have been successfully using hte legacy Blynk for quite some time.
Trying the new one with an Arduino MKR WIFI 1010 and am getting the following error:
"no matching function for call to ‘BlynkWifiCommon::begin(char [33])’
Should I be using different Blynk libraries?
#define BLYNK_TEMPLATE_ID "TMPLKML39M2h"
#define BLYNK_DEVICE_NAME "RRS"
#define BLYNK_AUTH_TOKEN "r4w1R4csliSCPPjtNLA-QH0FvcC2qzTp"
//#include <SPI.h>
//#include <Ethernet.h>
//#include <BlynkSimpleEthernet.h>
#include <WiFiNINA.h> // for mkr 1010
#include <BlynkSimpleWiFiNINA.h> // for Blynk
char ssid[] = "linksys1";
char pass[] = "";
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
// Set incoming value from pin V0 to a variable
int value = param.asInt();
// Update state
Blynk.virtualWrite(V1, value);
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
// Change Web Link Button message to "Congratulations!"
Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
Blynk.setProperty(V3, "onImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
Blynk.virtualWrite(V2, millis() / 1000);
Blynk.begin(auth);
//Blynk.begin(auth, "blynk.cloud", 80);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8080);
// to avoid delay() function!
