You’ll need:
- Blynk IoT app (download from App Store or Google Play)
- ESP8266 board
example.
/* Fill-in information from Blynk Device Info here */
#define BLYNK_TEMPLATE_ID "TMPL6FftOEUGf"
#define BLYNK_TEMPLATE_NAME "IOT"
#define BLYNK_AUTH_TOKEN "DtUWdySNRgGitU1Mieeq3Eta9TzzgpUk"
char ssid[] = "70S733";
char pass[] = "0870841702";
//Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass, "blynk.cloud", 80);
//Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass, IPAddress(192,168,1,100), 8080);
// to avoid delay() function!
i try other cable and port and reinstall blynk and esp8266 core and still not work
i just remember i uploaded a code 2 month ago before it error like this.
sorry didn’t mention you earlier
here’s code i upload before it’s get error message
// Blynk Template Information
// Lib include
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
float pHValue;
// WiFi Credentials
// TDS Sensor Configuration
#define TdsSensorPin A0
#define VREF 5.0
#define SCOUNT 30
int analogBuffer[SCOUNT];
int analogBufferTemp[SCOUNT];
int analogBufferIndex = 0, copyIndex = 0;
float averageVoltage = 0, tdsValue = 0, temperature = 25;
// Initialize Blynk and Serial
pinMode(TdsSensorPin, INPUT);
lcd.init();
lcd.backlight();
// Run Blynk
// TDS Sensor Sampling
static unsigned long analogSampleTimepoint = millis();
if (millis() - analogSampleTimepoint > 40U) {
analogBuffer[analogBufferIndex] = analogRead(TdsSensorPin);
analogBufferIndex++;
if (analogBufferIndex == SCOUNT)
analogBufferIndex = 0;
// TDS Sensor Processing
static unsigned long printTimepoint = millis();
if (millis() - printTimepoint > 800U) {
for (copyIndex = 0; copyIndex < SCOUNT; copyIndex++)
analogBufferTemp[copyIndex] = analogBuffer[copyIndex];
// Calculate average voltage
averageVoltage = getMedianNum(analogBufferTemp, SCOUNT) * (float)VREF / 1024.0;
// Temperature Compensation
float compensationCoefficient = 1.0 + 0.02 * (temperature - 25.0);
float compensationVoltage = averageVoltage / compensationCoefficient;
// Convert voltage to TDS value
tdsValue = (133.42 * compensationVoltage * compensationVoltage * compensationVoltage - 255.86 * compensationVoltage * compensationVoltage + 857.39 * compensationVoltage) * 0.5;
// Read pH value from Serial
String pHString = Serial.readStringUntil('\n');
float pHValue = pHString.toFloat();
delay(100);
// Serial & debug
//Serial.print("voltage:");
//Serial.print(averageVoltage,2);
//Serial.print("V ");
//Serial.print("TDS Value:");
//Serial.print(tdsValue,0);
//Serial.println("ppm");
//Serial.print(pHValue);
// Update Blynk virtual pins & Lcd
Blynk.virtualWrite(V1, tdsValue);
//Serial.print("V1Sended");
lcd.setCursor(0, 0);
lcd.print("ppm");
lcd.setCursor(5, 0);
lcd.print(tdsValue);
//Serial.print("tds lcded");
Blynk.virtualWrite(V2, pHValue);
//Serial.print("V2Sended");
lcd.setCursor(0, 1);
lcd.print("pH");
lcd.setCursor(5, 1);
lcd.print(pHValue);
//Serial.print("pH lcded");
// Function to calculate median of an array
int getMedianNum(int bArray[], int iFilterLen) {
int bTab[iFilterLen];
for (byte i = 0; i < iFilterLen; i++)
bTab[i] = bArray[i];
quickSort(bTab, 0, iFilterLen - 1);
if (iFilterLen % 2 != 0) {
return bTab[iFilterLen / 2];
return (bTab[iFilterLen / 2 - 1] + bTab[iFilterLen / 2]) / 2;
void quickSort(int arr[], int left, int right) {
int i = left, j = right;
int tmp;
int pivot = arr[(left + right) / 2];
while (i <= j) {
while (arr[i] < pivot)
i++;
while (arr[j] > pivot)
j--;
if (i <= j) {
tmp = arr[i];
arr[i] = arr[j];
arr[j] = tmp;
i++;
j--;
if (left < j)
quickSort(arr, left, j);
if (i < right)
quickSort(arr, i, right);
