BLYNK
EthernetWebServer for Mega,Teensy,SAM, SAMD boards with Ethernet W5X00, ENC28J60 shields
This is simple yet complete WebServer library for AVR, Teensy, etc. boards running Ethernet shields. The functions are similar and compatible to ESP8266/ESP32 WebServer libraries to make life much easier to port sketches from ESP8266/ESP32.
The library supports
  1. HTTP Server and Client
  2. HTTP GET and POST requests, provides argument parsing, handles one client at a time.
Library is based on and modified from:
  1. Ivan Grokhotkov’s ESP8266WebServer
The EthernetWebServer class found in EthernetWebServer.h header, is a simple web server that knows how to handle HTTP requests such as GET and POST and can only support one simultaneous client.
There currently are 6 examples:
  1. HelloServer
  2. HelloServer2
  3. AdvancedWebServer
  4. HttpBasicAuth
  5. PostServer
  6. SimpleAuthentication
This is the HelloServer
#include <Ethernet.h>
#include <EthernetWebServer.h>
#ifdef CORE_TEENSY
  // For Teensy 4.0
  #if defined(__IMXRT1062__)
  #define BOARD_TYPE      "TEENSY 4.0"
  #elif ( defined(__MKL26Z64__) || defined(ARDUINO_ARCH_AVR) )
  #define BOARD_TYPE      "TEENSY LC or 2.0"
  #else
  #define BOARD_TYPE      "TEENSY 3.X"
  #endif
#else
// For Mega
#define BOARD_TYPE      "AVR Mega"
#endif
// Enter a MAC address and IP address for your controller below.
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
// Select the IP address according to your local network
IPAddress ip(192, 168, 2, 100);
EthernetWebServer server(80);
const int led = 13;
void handleRoot()
  server.send(200, "text/plain", "Hello from EthernetWebServer");
void handleNotFound()
  String message = "File Not Found\n\n";
  message += "URI: ";
  message += server.uri();
  message += "\nMethod: ";
  message += (server.method() == HTTP_GET)?"GET":"POST";
  message += "\nArguments: ";
  message += server.args();
  message += "\n";
  for (uint8_t i=0; i<server.args(); i++)
    message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
  server.send(404, "text/plain", message);
  digitalWrite(led, 0);
void setup(void)
  // Open serial communications and wait for port to open:
  Serial.println("\nStarting HelloServer on " + String(BOARD_TYPE));
  // start the ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.on("/", handleRoot);
  server.on("/inline", [](){
    server.send(200, "text/plain", "This works as well");
  server.onNotFound(handleNotFound);
  server.begin();
  Serial.print(F("HTTP EthernetWebServer is @ IP : "));
  Serial.println(Ethernet.localIP());
void loop(void)
  server.handleClient();
Update Feb 17th 2020
EthernetWebServer libraries v1.0.0 just got included into Arduino Library Manager.
Now you can install this library directly from Arduino Library Manager.
Version v1.0.1
  1. Add support to Server’s lambda function calls with dependency on Functional-VLPP library
Update Feb 20th 2020
Version v1.0.2
  1. From v1.0.2+, the library supports many more Arduino boards (Atmel AVR-s, Atmel SAM3X8E ARM Cortex-M3, STM32F series, ESP8266, Intel ARC32(Genuino101), Nordic nRF51(RFduino), Teensy boards, Realtek Ameba(RTL8195A,RTL8710))
  2. Support Wiznet W5x00 or ENC28J60 EThernet shields by using UIPEthernet library besides standard Ethernet, Ethernet2, Ethernet3 libraries.
Update Feb 23rd 2020
Version v1.0.3
1.From v1.0.3+, the library supports more Arduino boards ( SAM DUE, SAMD: ZERO, MKR, NANO_33_IOT, M0, M0 Pro, AdaFruit CIRCUITPLAYGROUND_EXPRESS, etc.)
