Hi everyone, I ask for your help for a project I implemented by building on the DHT22 sensor reading sketch. I used an Arduino mega 2560 with ethernet shield W5100. It happens that if I do not connect the LAN cable to the ethernet shield, Arduino does not start. I guess I connect it, everything works regularly. And so even if, hypothetically, the router freezes or shuts off, it blocks everything.
Do you have suggestions? Thanks in advance
#include <Ethernet.h>
#include <Blynk.h>
#include <FastIO.h>
#include <I2CIO.h>
#include <LCD.h>
#include <LiquidCrystal.h>
#include <LiquidCrystal_SR.h>
#include <LiquidCrystal_SR2W.h>
#include <LiquidCrystal_SR3W.h>
#include <Wire.h>
#include <DHT.h>
#include <OneWire.h>
char auth[] = "ea0dcf471a02475ca22c000f6e3889e6";
IPAddress server_ip (46, 101, 143, 225);
#define W5100_CS 10
#define SDCARD_CS 4
#define DHTPIN 2 // What digital pin we're connected to
#define DHTPIN1 3 // What digital pin we're connected to
#define ONE_WIRE_BUS 7
#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
#define deum 9
#define vlv 8
DHT dht(DHTPIN, DHTTYPE);
DHT dht1(DHTPIN1, DHTTYPE);
WidgetLED LEDdeum(V3);
WidgetLED LEDvlv(V4);
byte range = 3;
int val = 0;
float h, t, h1, t1, td, td1, s1;
String deu, valve;
byte ultimo_pulsante;
byte page = 0;
byte freccia_su[8] = {
B00000,
B00000,
B00100,
B01110,
B11111,
B00000,
B00000,
B00000,
byte freccia_giu[8] = {
B00000,
B00000,
B00000,
B11111,
B01110,
B00100,
B00000,
B00000,
byte grado[8] = {
B00010,
B00101,
B00010,
B00000,
B00000,
B00000,
B00000,
B00000,
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
BLYNK_WRITE(V1) {
val = param.asInt(); // assigning incoming value from pin V1 to a variable
range = range + val;
Serial.println("pulsante remoto");
void sendSensor()
h = dht.readHumidity();
t = dht.readTemperature();
h1 = dht1.readHumidity();
t1 = dht1.readTemperature();
s1 = sensors.getTempCByIndex(0);
double a = 17.271;
double b = 237.7;
double tr = (a * t) / (b + t) + log(h / 100);
td = (b * tr) / (a - tr);
double tr1 = (a * t1) / (b + t1) + log(h1 / 100);
td1 = (b * tr1) / (a - tr1);
Blynk.virtualWrite(V0, range);
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
Blynk.virtualWrite(V7, h1);
Blynk.virtualWrite(V8, t1);
Blynk.virtualWrite(V9, s1);
Blynk.virtualWrite(V10, td);
Blynk.virtualWrite(V11, td1);
{ lcd.begin(20, 4);
lcd.clear();
lcd.createChar(1, freccia_su);
lcd.createChar(2, freccia_giu);
lcd.createChar(3, grado);
lcd.setCursor(0, 0);
lcd.print("CONTROLLO ");
lcd.setCursor(0, 1);
lcd.print("DEUMIDIFICAZIONE");
lcd.setCursor(0, 2);
lcd.print("Premere ENTER ");
lcd.setCursor(0, 3);
lcd.print("per accedere ai menu");
page = 0;
pinMode(deum, OUTPUT);
pinMode(vlv, OUTPUT);
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
//Blynk.begin(auth, server_ip, 8442);
//Blynk.begin(auth, "blynk-cloud.com", 8442);
Blynk.begin(auth, IPAddress(server_ip), 8442);
dht.begin();
sensors.begin();
//timer.setInterval(500L, sendSensor);
digitalWrite (deum, HIGH);
digitalWrite (vlv, LOW);
{ Serial.println("Inizia");
//timer.run();
sendSensor();
onoff();
lettura_pulsanti();
richiama_update();
if ((page == 4) || (page == 5) || (page == 6) || (page == 7) || (page == 8) || (page == 4)) {
Serial.println("OK");
Serial.println("OKK");
updateLcd();
