Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code.
Code should be formatted as example below.
http://twitter.com/blynk_app
This example runs directly on ESP8266 chip.
Please be sure to select the right ESP8266 module
in the Tools -> Board menu!
#include <BlynkSimpleEsp8266_SSL.h>
char auth[] = "VaTnxSH_UR5CYPbHUIUz_lv93njmUI-5";
char ssid[] = "MMVS";
char pass[] = "Shreekl@123";
He has not installed his ESP core.
