Continuing the discussion from The smallest Wifi smartphone controlled 4WD car using ESP8266, Blynk and Arduino Code:
Hi sir,
I am interested in the above mentioned project and I am not engineering person but love to build up projects like this.
Here I am dissapointed that when I try to compile the sketch it shows error esp8266wifi.h library not found. I tried each and every thing that was mentioned on Google but with no results.
Is there any broken link.
I am using arduino ide 1.8.9 and successfully downloaded blynk library and esp8266 by esp community board.
Can you please help me out regarding this.
My email address guptamamtesh71@gmail.com
It will be very helpful of you if you can help me.
Have you installed the ESP8266 core ? If not use this link
http://arduino.esp8266.com/Arduino/versions/2.0.0/doc/installing.html
Paste this link in the arduino IDE preferences
http://arduino.esp8266.com/stable/package_esp8266com_index.json
Thanks for your cooperation, I will try it today.
Hi madhukesh I have tried everything but failed to do it on arduino can I do the same by using nodemcu flasher.
It would be much better if when a forum user asks you a specific question, you answer that question rather saying “I have tried everything”.
Hi sir, I have every possible way to compile the sketch and everytime an error occurs.
As I am only a hobbyist and no knowledge of coding and I have previously made a Wi-Fi car with help of tutorials mentioned in you tube videos and other sites.
I have been trying from last four days.
Can you please help me.
The error message I have mentioned earlier.
Thanks for your comment.
Have you installed the ESP core ? If yes then compile the code given below. Even then if you get errors then you have not installed the CORE. I have got the code compiled here.
Wifi/Blynk controlled 4WD car using ESP 8266
Used Pin ESP07
D5-14 motorA1 ; D6-12 motorA2
D1-05 motorB1 ; D2-04 motorB2
D4-02 Rightflasher
RX-03 Leftflasher
D7-13 Headlight ; tx-01 buzzer
int X = 512;
int Y = 512;
int maximo = 0;
int Rflasher = 0;
int Lflasher = 0;
int buzzer = 0;
int police = 0;
int flasherLedState = LOW; //Initial led state
long previousMillis = 0; // Time control
long flasherLedInterval = 300; // Interval time to run
#define RED 0
#define BLUE 0
byte whichLED = RED;
byte Red_State = LOW;
byte Red1_State = LOW;
unsigned long switchDelay = 250;
unsigned long strobeDelay = 50;
unsigned long strobeWait = strobeDelay;
unsigned long waitUntilSwitch = switchDelay; // Initial state
char auth[] = "xxxxxxxxxxxx"; // You should get Auth Token in the Blynk App.
Serial.begin(9600);// Set console baud rate
Blynk.begin(auth, "SSID", "PASS");// You will connect your phone to this Access Point and this is the password
pinMode(14, OUTPUT); // Pin motor A1
pinMode(12, OUTPUT); // Pin motor A2
pinMode(2, OUTPUT); // Pin Rightflasher
pinMode(3, OUTPUT); // Pin Leftflasher
pinMode(5, OUTPUT); // Pin motor B1
pinMode(4, OUTPUT); // Pin motor B2
pinMode(1, OUTPUT); // PinoBuzzer
BLYNK_WRITE(V1) // 0~1023
int X1 = param[0].asInt();
X = X1;
int Y1 = param[1].asInt();
Y = Y1;
BLYNK_WRITE(V2)// slider PWM from 0 to 1023
maximo = param.asInt();
BLYNK_WRITE(V3) // button Rightflasher
Rflasher = param.asInt();
BLYNK_WRITE(V4) // button Leftflasher
Lflasher = param.asInt();
BLYNK_WRITE(V5) // button buzzer
buzzer = param.asInt();
BLYNK_WRITE(V7) // button police
police = param.asInt();
if (X != 512 && Y != 512)
if ( X > 311 && X < 711 && Y > 311 && Y < 711 ) // Motor Stop
analogWrite(14, 0); //IN-1A motorA = 0
analogWrite(12, 0); //IN-1B
analogWrite(5, 0); //IN-2A motorB = 0
analogWrite(4, 0); //IN-2B
if ( X > 311 && X < 711 && Y > 711) // motor forward
analogWrite(14, maximo); //motorA = maximo;
analogWrite(12, 0);
analogWrite(5, maximo);//motorB = maximo;
analogWrite(4, 0);
if ( X > 311 && X < 711 && Y < 311) // Motor backward
analogWrite(12, maximo);// motorA = maximo;
analogWrite(14, 0);
analogWrite(5, maximo);// motorB = maximo;
analogWrite(4, 0);
if ( X > 711 && Y > 711) // Right Forward
analogWrite(14, maximo);//motorA = maximo;
analogWrite(12, 0);
analogWrite(5, 0);//motorB = 0;
analogWrite(4, 0);
if ( X < 311 && Y > 711) // Left Forward
analogWrite(14, 0);//motorA = 0;
analogWrite(12, 0);
analogWrite(4, 0);
if ( X > 711 && Y < 311) // Right backwards
analogWrite(12, maximo);//motorA = maximo;
analogWrite(14, 0);
analogWrite(5, 0 );//motorB = 0;
analogWrite(4, 0);
if ( X < 311 && Y < 311) // Left backwards
analogWrite(12, 0);//motorA = 0;
analogWrite(14, 0);
analogWrite(4, 0);
if (Rflasher != 1 && Lflasher != 1)
if (police == 1)
digitalWrite(2, Red_State);
digitalWrite(3, Red1_State);
if ((long)(millis() - waitUntilSwitch) >= 0) {
// time is up!
Red_State = LOW;
Red1_State = LOW;
whichLED = !whichLED; // toggle LED to strobe
waitUntilSwitch += switchDelay;
// police effect
if ((long)(millis() - strobeWait) >= 0) {
if (whichLED == RED)
Red_State = !Red_State;
if (whichLED == BLUE)
Red1_State = !Red1_State;
strobeWait += strobeDelay;
digitalWrite(2, LOW);
digitalWrite(3, LOW);
unsigned long currentMillis = millis(); //Current time
if (currentMillis - previousMillis > flasherLedInterval) //Logic of time verification
previousMillis = currentMillis; // Saves the current time
if (flasherLedState == LOW)
flasherLedState = HIGH;
if (Rflasher == 1 && police == 0)
digitalWrite(2, flasherLedState);
if (Lflasher == 1 && police == 0)
digitalWrite(3, flasherLedState);
if (buzzer == 1)
tone(1, 500, 200); //Horn tone "FA"
And also install the latest Blynk library. GitHub - blynkkk/blynk-library: Blynk library for IoT boards. Works with Arduino, ESP32, ESP8266, Raspberry Pi, Particle, ARM Mbed, etc.
There are many tutorials out there on how to install library.
To do this you need to have the .bin file of the project. Only then the flasher you are mentioning can flash the nodemcu. There is no option to type the code or push the .ino file on to the flasher(as per my knowledge).
Now you can try the above given code and compile it. It should compile.
Arduino 1.8.7
ESP core 2.4.2
Blynk lib 0.6.0
You can install the latest versions if you need.
Thanks a lot for your kind cooperation and precious time to spend with me. God bless you.
The code is compiling now.
Thanks again.
Hi I uploaded the sketch successfully but I am not able to connect esp with blynk app.
Have you entered all your credentials correctly ?
SSID
PASS
Server (if running on a local server)
AUTH
Show the sketch you are uploading.
Make sure you are entering all the credentials i mentioned above without any mistakes.
Used Pin ESP07
D4-02 Rightflasher
RX-03 Leftflasher
int X = 512;
int Y = 512;
int maximo = 0;
int Rflasher = 0;
int Lflasher = 0;
int buzzer = 0;
int police = 0;
#define RED 0
#define BLUE 0
char auth [ ] =
";AUTH" // You should get Auth Token in the Blynk App.
Blynk.begin(auth, "Wificar", "1234567890");// You will connect your phone to this Access Point and this is the password
X = X1;
Y = Y1;
analogWrite(12, 0);
analogWrite(4, 0);
analogWrite(14, 0);
analogWrite(4, 0);
analogWrite(12, 0);
analogWrite(4, 0);
analogWrite(12, 0);
analogWrite(4, 0);
analogWrite(14, 0);
analogWrite(4, 0);
analogWrite(14, 0);
analogWrite(4, 0);
if (police == 1)
// time is up!
Red_State = LOW;
Red1_State = LOW;
// police effect
if (buzzer == 1)
I am connecting by my mobile hot-spot
Used Pin ESP07
D4-02 Rightflasher
RX-03 Leftflasher
Can you please check the pin configuration
And let me know which virtual pin is for buzzer, headlight, motors, flasher, speed mentioned in the sketch I am also sending a screen shot of video.
Screenshot_2020-04-02-19-38-14|690x388
Have a look at the semicolon in the beginning of the auth token. Make sure its out side the double quotes.
Use Virtual pins V1,2,3,4,5,7
As virtual pins on the app settings.
This is my typing error occurred while pasting on the site rest is OK. I have double check everything.
Hi sir one thing more there is option of headlight but it seems no pin is assigned for it .
Which pin is configured for headlight.
Used Pin ESP07
D4-02 Rightflasher
RX-03 Leftflasher
What type of connection must I use if I am connecting blynk app by my mobile hot-spot.
Thanks again to guide me through out my project.
I have damaged one nodemcu and three esp8266 module to make this project successful but I am not going to give up until I fix it.
WiFi, assuming that your cellular data provider doesn’t block the Blynk data packets over the hotspot. Also, I’m not sure if you will be able to successfully run the hotspot and the Blynk app on the same device.
Thanks Sir.
