ESP8266 + WS-420 + Blynk
Could anyone assist in the code to enable blynk to record the vibration levels from the above combinations.
more than greatful.
I assume you mean SW-420 ?
The forum isn’t a code factory, and you’re unlikely to find a forum member that is going to provide you with a working solution.
If you have good C++ programming skills, and can articulate exactly what it is that you are trying to achieve with your project, then you’ll probably be able to get some assistance with adding Blynk to a working sketch.
Thanks for the reply, I am 74 yrs old and have no programing experience. I have a working program for the ESP 8622 but do not know how to intergrate blynk to achieve my aims.
If you share your working program (post the code with triple backticks at tge beginning and end) and explain exactly what it is that you’re trying to achieve then I’m sure you’ll get some help.
