#define BLYNK_TEMPLATE_ID "TMPL6NTDwdNKR"
#define BLYNK_TEMPLATE_NAME "Test"
#define BLYNK_AUTH_TOKEN "zv6xqv9T48p_CZRugqKPPrgL88bI7SiQ"
char ssid[] = "PLDTHOMEFIBR5G679a8"; // WiFi SSID
char pass[] = "PLDTWIFItcwy5"; // WiFi password
BlynkTimer timer; // Creating a timer object
void myTimerEvent() // This loop defines what happens when timer is triggered
Blynk.virtualWrite(A0, millis() / 1000);
Serial.begin(9600); // initialize serial communication at 9600 bits per second
Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass, "https://sgp1.blynk.cloud.com"); // connect to Blynk server
timer.setInterval(1000L, myTimerEvent); //Staring a timer
if (Serial.available() > 0) { // check if there is any data available from Arduino
String sensorData = Serial.readStringUntil('\n'); // read the data until newline character
sensorData.trim(); // remove any whitespace characters
int sensorValue = sensorData.toInt(); // convert the data to integer
Blynk.virtualWrite(A0, sensorValue); // send the value to Blynk app
if (Blynk.connected()) {
Serial.println("NodeMCU is connected to Blynk app.");
Serial.println("NodeMCU is not connected to Blynk app.");
Blynk.run(); // run Blynk app
I’m trying to get my ESP8266 to connect to the Blynk app but no matter what I do it just won’t connect. I’m trying to get the moisture sensor data to go to the app but the microcontroller just will not connect to the Blynk app.
The ESP8266 definitely can connect to the Wifi as I’ve already performed the Wifi scan and it definitely works. But when I run this code, my device on the dashboard remains as “offline.”
I was just trying a bunch of stuff and thought that it might work but it didn’t. But I already got it working. The issue now is that on the app instead of displaying values that should extend from 500 to 1000. The app just shows a value of one.
This is the new code btw:
#define BLYNK_AUTH_TOKEN "syysCAdzqT24ruX4lMJxzVZvbdi86at2"
char ssid[] = "PLDTHOMEFIBR679a8"; // WiFi SSID
SoftwareSerial ardSerial(D9, D10);
Blynk.virtualWrite(V1, millis() / 1000);
WiFi.begin(ssid, pass);
Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass); // connect to Blynk server
Serial.println(ardSerial.read());
int sensorValue = ardSerial.read(); // convert the data to integer
Blynk.virtualWrite(V1, sensorValue); // send the value to Blynk app
I think this is what you mean by serial printing the sensor value. Yes the values I want do show up on the serial monitor so I’m pretty sure I did do that.
It shows up on the serial monitor but not on the Blynk app itself.
And I have already defined the min/max values on the data stream as I show on the picture above. It says from 0 to 1032 but when I activate the system it still just displays 1.
Once you’ve made this change please copy/paste the text from your serial monitor, from the point when your device boots. Use triple backticks at the beginning and end of the text when you post it, like you did with your sketch.
