ESP8266 WIFI Witty Cloud Development Board ESP-12F Module MINI Nodemcu
http://www.icstation.com/esp8266-wifi-witty-cloud-development-board-module-mini-nodemcu-p-8154.html
Video: https://www.youtube.com/watch?v=Ymi7DNY4vNg
Description:
- This cheap and small Wifi transciever is the perfect solution for
home Automation and IoT applications. It can be the replacement of your
NRF24L01, it can talk to your Wifi router directly through the UART
MCU’s (Rx, Tx). - The ESP-12 module is one of the most complete of the ESP family as
it allows you to use biggest amount of pins of all of them. You can
program this module to work stand alone with the Arduino IDE or with LUA
as NodeMCU. - It has an LDR and a WS2812 led already on board for your projects.
The board comes with a CH40 micro USB module to program it. - The ESP8266 highly integrated chip, including antenna switch balun,
power management converter, so with minimal external circuitry. The
system is equipped with ESP8266 manifested leading features are: energy
saving VoIP quickly switch between the sleep / wake patterns, with
low-power operation adaptive radio bias, front-end signal processing
functions. - This version, the ESP8266-03 is one of the smallest versions of this module. It includes a buil-in ceramic antenna.
Specifications:
- LDR Lignt Sensor on board
- WS2812 Led on board
- 3x tactile buttons (1x in the Witty board and 2x in theCH340 board)
- Supports 3 modes: AP,STA,AP+STA
- Dimensions: 24mm x 16mm
- Micro USB connection for power and/or programming
