And what’s the problem or bug? Are you trying to connect to your local server or cloud? As per your config you’re connecting to cloud… credentials from cloud or local server?
connect to cloud
my full code have http update code block and work fine on ip 192,168,1,55 but esp not connect to blynk-cloud.com:80 with blynk library 0.5.4
Port 8442 from the device is “obsolete” now… should be port 80 for Cloud (although 8080 should also work) or 443 for Cloud SSL.
There have also been some past issues when trying to connect from within Russia… no idea if those issues still exist
Probably just carry-over backward compatibility… but having such older library will cause other compatibility issues with the App… so should always be kept current.
Sounds like something needs to be adjusted in your router settings then. Not sure how it is affected by eh library except possibly due to the port routing. But again, best to keep up with the imes else you will run into other App compatibility issues.
