I could really use some help. I have a reef aquarium and I built the LED lights that I use to keep my coral alive. I found a project on an aquarium forum that used Blynk, an ESP8266, and custom driver PCB to control LED lights. Everything worked great for a couple years, but obviously with the switch from the legacy Blynk app my lights don’t work anymore. While I have no problem figuring stuff out on the hardware side of things, I know next to nothing about writing code. Is anyone willing to walk me through the process of migrating this project over to the new Blynk app? If I can’t figure this out I’m going to have to spend a lot on new lights and I’m a student so I don’t really have the budget for that.
Here is the project that I used
Here is a screenshot of the app (limited to one image)
Here is the code. Let me know if there is anything else that I need to provide.
ESP_Blynk_LED_Controller
#include <FS.h> // https://github.com/tzapu/WiFiManager This Library needs to be included FIRST!
#include <ArduinoOTA.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
#include <OneWire.h> // network library to communicate with the DallasTemperature sensor,
#include <DallasTemperature.h> // library for the Temp sensor itself
//included libraries for WiFiManager - AutoConnectWithFSParameters
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
#include <ArduinoJson.h> //https://github.com/bblanchon/ArduinoJson
#include <EEPROM.h>
void updateBlynkSliders(boolean updateAll=true);
byte pSDA=4;
byte pSCL=5;
byte pEnFAN=2; //D0
byte pFANPWM=0;
byte pOneWire=13;
byte pOnBoardLED=16; //D4
// WiFiManager
char blynk_token[34] = "BLYNK_TOKEN";//added from WiFiManager - AutoConnectWithFSParameters
//flag for saving data
bool shouldSaveConfig = false;
//callback notifying the need to save config
void saveConfigCallback () {
BLYNK_LOG("Should save config");
shouldSaveConfig = true;
bool isFirstConnect = true;
bool smartStartupRun = false;
bool appConnected = false;
char Time[16];
unsigned long startsecond = 0; // time for LEDs to ramp to full brightness
unsigned long stopsecond = 0; // finish time for LEDs to ramp to dim level from full brightness
unsigned long sunriseSecond = 0; // time for LEDs to start ramping to dim level
unsigned long sunsetSecond = 0; // finish time for LEDs to dim off
unsigned long moonStartSecond = 0; // time for LEDs to start ramping to moonlight level
unsigned long moonStopSecond = 0; // time for LEDs to ramp off
unsigned long nowseconds = 0; // time now in seconds
//0=not ramping, 3=moon->dim, 4=dim->max, 5=max->dim, 6=dim->moon
unsigned int fadeInProgress = 0;
unsigned long fadeStartTimeMillis = 0;
unsigned long fadeStartTimeSeconds = 0;
unsigned long fadeTimeSeconds = 0;
unsigned long fadeTimeMillis = 0;
struct LEDCh // for storing light intensity values
unsigned int fadeIncrementTime;
unsigned int currentPWM;
unsigned int lastPWM;
unsigned int targetPWM;
unsigned int maxPWM;
unsigned int dimPWM;
unsigned int tempPWM;
unsigned int moonPWM;
typedef struct LEDCh channel;
const int numCh = 6;
channel LEDsettings[numCh];
int LEDMode = 1; //1=operating, 2=Configure MaxPWM, 3=Configure dimPWM, 4=Configure moonPWM
// Data wire is plugged into port 2 on the Wemos
#define ONE_WIRE_BUS D7
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
// Pass our oneWire reference to Dallas Temperature.
// array to hold device addresses (can increase array length if using more sensors)
DeviceAddress tempSensors[3];
int numTempSensors;
int fanOnTemp = 0;
WidgetRTC rtc;
WidgetLED fanLED(V14);
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
Wire.begin(pSDA,pSCL);
//Wire.setClock(400000L);
ArduinoOTA.begin();
pinMode(pOnBoardLED, OUTPUT);
pinMode(pFANPWM, OUTPUT);
pinMode(pEnFAN, OUTPUT);
digitalWrite(pOnBoardLED, LOW);
digitalWrite(pFANPWM, LOW);
digitalWrite(pEnFAN, LOW);
pwm.begin();
pwm.setPWMFreq(250);
//Start dallas temperature temp sensors
sensors.begin();
// locate devices on the bus
numTempSensors = sensors.getDeviceCount();
BLYNK_LOG("Found %d temperature sensors.",numTempSensors);
for( int i = 0 ; i < numTempSensors ; i++)
if (!sensors.getAddress(tempSensors[i], i))
BLYNK_LOG("Unable to find address for Device %d",i);
//The following code is borrowed from WiFiManager
//clean FS, for testing
//SPIFFS.format();
//read configuration from FS json
BLYNK_LOG("Mounting FS...");
if (SPIFFS.begin()) {
BLYNK_LOG("Mounted file system");
if (SPIFFS.exists("/config.json")) {
//file exists, reading and loading
BLYNK_LOG("Config file exists");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
BLYNK_LOG("Opened config file");
size_t size = configFile.size();
// Allocate a buffer to store contents of the file.
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
json.printTo(Serial);
if (json.success()) {
BLYNK_LOG("Parsed json");
strcpy(blynk_token, json["blynk_token"]);
BLYNK_LOG("Blynk Token in memory: %s",blynk_token);
BLYNK_LOG("Failed to load json config");
}else{
BLYNK_LOG("File config.json does not exist",blynk_token);
BLYNK_LOG("Failed to mount FS");
//end read
// The extra parameters to be configured (can be either global or just in the setup)
// After connecting, parameter.getValue() will get you the configured value
// id/name placeholder/prompt default length
WiFiManagerParameter custom_blynk_token("blynk", "blynk token", blynk_token, 34);
// WiFiManager
// Local intialization. Once its business is done, there is no need to keep it around
WiFiManager wifiManager;
// Set config save notify callback
wifiManager.setSaveConfigCallback(saveConfigCallback);
// Add blynk parameter here
wifiManager.addParameter(&custom_blynk_token);
// Reset settings - for testing
//wifiManager.resetSettings();
//set minimu quality of signal so it ignores AP's under that quality (default: 8%)
wifiManager.setMinimumSignalQuality();
// Sets timeout until configuration portal gets turned off
// useful to make it all retry or go to sleep
//wifiManager.setTimeout(120);
//fetches ssid and pass and tries to connect
//if it does not connect it starts an access point with the specified name
//and goes into a blocking loop awaiting configuration
if (!wifiManager.autoConnect("LED AP")) {
//Serial.println("failed to connect and hit timeout");
BLYNK_LOG("Failed to connect and hit timeout");
delay(3000);
//reset and try again, or maybe put it to deep sleep
ESP.reset();
BLYNK_LOG("LED Controller connected :)");
//read updated parameters
strcpy(blynk_token, custom_blynk_token.getValue());
//save the custom parameters to FS
if (shouldSaveConfig) {
BLYNK_LOG("Saving config");
JsonObject& json = jsonBuffer.createObject();
json["blynk_token"] = blynk_token;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
BLYNK_LOG("failed to open config file for writing");
json.printTo(configFile);
configFile.close();
//end save
setSyncInterval(1000); //make sure time syncs right away
Blynk.config(blynk_token);
while (Blynk.connect() == false)
// Wait until connected, need to handle case where wifi connects but blynk auth invalid...
if((shouldSaveConfig == false)&&(blynk_token == "BLYNK_TOKEN"))
//This will erase WiFi settings forcing a new AP where Blynk_token can be entered
//WiFi.disconnect(true);
//ESP.reset();
//OR
WiFi.begin("xxxxxx","xxxxxxx"); // Replace current WiFi credentials with fake ones
ESP.restart();
rtc.begin();
//Can update slider colors here if desired
//Blynk.setProperty(V0, "color", "#F2FAFF"); // COOL WHITE
//Blynk.setProperty(V1, "color", "#FFEDE0"); // WARM WHITE
//Blynk.setProperty(V2, "color", "#FD5635"); // RED
//Blynk.setProperty(V3, "color", "#BFFFB3"); // LIME
//Blynk.setProperty(V4, "color", "#2E28FF"); // ROYAL BLUE
//Blynk.setProperty(V5, "color", "#2ECEFF"); // CYAN
//Blynk.setProperty(V6, "color", "#FD5635"); // RED
//Blynk.setProperty(V7, "color", "#BD1313"); // DEEP RED
//Read LED settings from EEPROM
if(checkEEPROMPWM() == false)
//if the EEPROM has not been set previously clear memory
clearPWMValues();
readPWMValues();
timer.setInterval(500L, ledFade); // adjust the led lighting every 500ms
timer.setInterval(1000L, checkSchedule); // check every second if fade should start
timer.setInterval(15000L, checkTemp); // check heatsink temperature every 15 seconds
timer.setInterval(60000L, reconnectBlynk); // check every 60s if still connected to server
digitalWrite(pOnBoardLED, HIGH); //ensure light is OFF
Blynk.notify("LED Controller ONLINE");
BLYNK_LOG("End of startup.");
ArduinoOTA.handle();
if (Blynk.connected()) {
//===Functions===
void reconnectBlynk() {
if (!Blynk.connected())
//Turn onboard LED on to indiciate there is an issue
if (Blynk.connect())
BLYNK_LOG("Reconnected");
else {
BLYNK_LOG("Not reconnected");
}else
//Turn onboard LED off
clockDisplay();
void checkSchedule() // check if ramping should start
if (year() != 1970)
nowseconds = ((hour() * 3600) + (minute() * 60) + second());
//nowseconds = elapsedSecsToday(now());
unsigned long timingInfo = startsecond + sunriseSecond + moonStartSecond + fadeTimeSeconds;
if((smartStartupRun == false)&&(timingInfo != 0))
smartLEDStartup();
smartStartupRun = true;
setSyncInterval(600000); //set time sync to every 10 minutes
}else
nowseconds = 86401; //set seconds out of range to avoid un-wanted ramps
int i;
int difference;
if((nowseconds == sunriseSecond)&&(fadeInProgress != 4)) //ramp from 0 to sunrise values
sprintf(Time, "%02d:%02d:%02d", hour() , minute(), second());
BLYNK_LOG("%s\tStarting sunrise...",Time);
fadeInProgress = 4;
fadeStartTimeMillis = millis();
fadeStartTimeSeconds = now();
for(i = 0; i < numCh; i = i + 1) {
LEDsettings[i].targetPWM = LEDsettings[i].dimPWM;
LEDsettings[i].lastPWM = LEDsettings[i].currentPWM;
if(LEDsettings[i].targetPWM > LEDsettings[i].lastPWM){difference = (LEDsettings[i].targetPWM - LEDsettings[i].lastPWM);}
if(LEDsettings[i].targetPWM < LEDsettings[i].lastPWM){difference = (LEDsettings[i].lastPWM - LEDsettings[i].targetPWM);}
LEDsettings[i].fadeIncrementTime = fadeTimeMillis / difference;
else if((nowseconds == startsecond)&&(fadeInProgress != 5)) //ramp from sunrise to max
BLYNK_LOG("%s\tRamping to full brightness...",Time);
fadeInProgress = 5;
for (i = 0; i < numCh; i = i + 1) {
LEDsettings[i].targetPWM = LEDsettings[i].maxPWM;
else if((nowseconds == stopsecond)&&(fadeInProgress != 6)) //ramp from max to sunset values
BLYNK_LOG("%s\tStarting sunset...",Time);
fadeInProgress = 6;
else if((nowseconds == sunsetSecond)&&(fadeInProgress != 7)) //ramp from sunset to off
BLYNK_LOG("%s\tRamping LEDs off...",Time);
fadeInProgress = 7;
LEDsettings[i].targetPWM = 0;
else if((nowseconds == moonStartSecond)&&(fadeInProgress != 8)) //ramp from off to moon
BLYNK_LOG("%s\tRamping LEDs to moonlight...",Time);
fadeInProgress = 8;
LEDsettings[i].targetPWM = LEDsettings[i].moonPWM;
else if((nowseconds == moonStopSecond)&&(fadeInProgress != 9)) //ramp off from moon
fadeInProgress = 9;
if(appConnected)
//if we're in normal mode and ramping keep the sliders updated
if((LEDMode == 1)&&(fadeInProgress != 0))
//only update one slider per second to reduce traffic
updateBlynkSliders(false);
void ledFade()
int i;
if(fadeInProgress != 0)
unsigned long timeElapsed = millis() - fadeStartTimeMillis; //time since the start of fade
if(LEDsettings[i].currentPWM != LEDsettings[i].targetPWM)
//if adjustments are necessary
if(LEDsettings[i].lastPWM < LEDsettings[i].targetPWM)
//value increasing
LEDsettings[i].currentPWM = LEDsettings[i].lastPWM + (timeElapsed / LEDsettings[i].fadeIncrementTime);
if(LEDsettings[i].lastPWM > LEDsettings[i].targetPWM)
//value decreasing
LEDsettings[i].currentPWM = LEDsettings[i].lastPWM - (timeElapsed / LEDsettings[i].fadeIncrementTime);
//if target == last set to target
if(LEDsettings[i].lastPWM == LEDsettings[i].targetPWM)
LEDsettings[i].currentPWM = LEDsettings[i].targetPWM;
LEDsettings[i].currentPWM = constrain(LEDsettings[i].currentPWM,0,4095);
if(now() > (fadeStartTimeSeconds + fadeTimeSeconds))
fadeInProgress = 0;
if(LEDMode==1)
writeLEDs();
void writeLEDs() {
int i;
pwm.setPWM(i,0,LEDsettings[i].currentPWM);
void checkTemp()
//read all sensors and keep track of maximum temperature
float temperature[numTempSensors];
float maxTemperature = 0.0;
int i = 0;
for(i = 0 ; i < numTempSensors ; i++)
temperature[i] = sensors.getTempC(tempSensors[i]);
if(temperature[i] > maxTemperature)maxTemperature=temperature[i];
//write the maximum temperature to Blynk
Blynk.virtualWrite(V20, maxTemperature);
//if higher than fan set temperature then turn fan on
int intTemp = maxTemperature; //temp as integer
if(intTemp > fanOnTemp)
//Calculate PWM by temp over fanOnTemp, at 0C above run at 10%, 20C above 100%
int fanPWM = intTemp - fanOnTemp;
fanPWM = constrain(fanPWM,0,20);
fanPWM = map(fanPWM,0,20,10,1023);
analogWrite(pFANPWM,fanPWM);
//turn fan on
digitalWrite(pEnFAN,HIGH);
fanLED.on();
if(intTemp < (fanOnTemp-2))
//turn fan off
digitalWrite(pEnFAN,LOW);
analogWrite(pFANPWM,0);
fanLED.off();
void smartLEDStartup()
int i = 0;
int difference;
int secondsIntoRamp = 0;
unsigned long tempFadeTimeMillis;
BLYNK_LOG("nowseconds: %d", nowseconds);
//0=off, 1=moonPWM, 2=dimPWM, 3=maxPWM,
//4=Ramp off->dim, 5=Ramp dim->max, 6=Ramp max->dim, 7=Ramp dim->off, 8=Ramp off->moon, 9=Ramp moon->off
byte LEDStartMode = 99;
/* General shape of ramps:
* | 2e-----3s | -(maxPWM)
* | 1e----2s 3e-----4s | -(dimPWM)
* | / \ 5e-|-6s -(moonPWM)
* |--1s 4e---5s | 6e-- -(off)
* |_________________________________________________|________
for(i=0 ; i < nowseconds ; i++)//go through the schedule up to the current time
if(i == sunriseSecond){LEDStartMode = 4;secondsIntoRamp = 0;}
if((i == (sunriseSecond + fadeTimeSeconds))&&(LEDStartMode == 4))LEDStartMode = 2;
if(i == startsecond){LEDStartMode = 5;secondsIntoRamp = 0;}
if((i == (startsecond + fadeTimeSeconds))&&(LEDStartMode == 5))LEDStartMode = 3;
if(i == stopsecond){LEDStartMode = 6;secondsIntoRamp = 0;}
if((i == (stopsecond + fadeTimeSeconds))&&(LEDStartMode == 6))LEDStartMode = 2;
if(i == sunsetSecond){LEDStartMode = 7;secondsIntoRamp = 0;}
if((i == (sunsetSecond + fadeTimeSeconds))&&(LEDStartMode == 7))LEDStartMode = 0;
if(i == moonStartSecond){LEDStartMode = 8;secondsIntoRamp = 0;}
if((i == (moonStartSecond + fadeTimeSeconds))&&(LEDStartMode == 8))LEDStartMode = 1;
if(i == moonStopSecond){LEDStartMode = 9;secondsIntoRamp = 0;}
if((i == (moonStopSecond + fadeTimeSeconds))&&(LEDStartMode == 9))LEDStartMode = 0;
secondsIntoRamp++;
if(LEDStartMode == 99)//if we don't hit a ramp, ie if it's 12:01AM, go backwards
i = 86399;
while((LEDStartMode == 99)&&(i > nowseconds))
if(i == sunriseSecond)LEDStartMode = 4;
if(i == (sunriseSecond + fadeTimeSeconds))LEDStartMode = 2;
if(i == startsecond)LEDStartMode = 5;
if(i == (startsecond + fadeTimeSeconds))LEDStartMode = 3;
if(i == stopsecond)LEDStartMode = 6;
if(i == (stopsecond + fadeTimeSeconds))LEDStartMode = 2;
if(i == sunsetSecond)LEDStartMode = 7;
if(i == (sunsetSecond + fadeTimeSeconds))LEDStartMode = 0;
if(i == moonStartSecond)LEDStartMode = 8;
if(i == (moonStartSecond + fadeTimeSeconds))LEDStartMode = 1;
if(i == moonStopSecond)LEDStartMode = 9;
if(i == (moonStopSecond + fadeTimeSeconds))LEDStartMode = 0;
secondsIntoRamp = 86400 - i;
i--;
//set LEDs based on LEDStartMode
if(LEDStartMode == 0)
BLYNK_LOG("Setting lights off based on current time...");
for (i = 0; i < numCh; i = i + 1){LEDsettings[i].currentPWM = 0;}
fadeInProgress = 0;
else if(LEDStartMode == 1)
BLYNK_LOG("Setting lights to moonlight mode based on current time...");
for (i = 0; i < numCh; i = i + 1){LEDsettings[i].currentPWM = LEDsettings[i].moonPWM;}
fadeInProgress = 0;
else if(LEDStartMode == 2)
BLYNK_LOG("Setting lights to sunrise/set levels based on current time...");
for (i = 0; i < numCh; i = i + 1){LEDsettings[i].currentPWM = LEDsettings[i].dimPWM;}
fadeInProgress = 0;
else if(LEDStartMode == 3)
BLYNK_LOG("Setting lights to daylight levels based on current time...");
for (i = 0; i < numCh; i = i + 1){LEDsettings[i].currentPWM = LEDsettings[i].maxPWM;}
fadeInProgress = 0;
else //if we're mid ramp
fadeInProgress = LEDStartMode;
if(LEDStartMode == 4)
BLYNK_LOG("Setting lights to sunrise mode based on current time...");
LEDsettings[i].lastPWM = 0;
if(LEDStartMode == 5)
BLYNK_LOG("Setting lights to ramp up to daylight mode based on current time...");
LEDsettings[i].lastPWM = LEDsettings[i].dimPWM;
if(LEDStartMode == 6)
BLYNK_LOG("Setting lights to ramp down from daylight based on current time...");
LEDsettings[i].lastPWM = LEDsettings[i].maxPWM;
if(LEDStartMode == 7)
BLYNK_LOG("Setting lights to sunset mode based on current time...");
if(LEDStartMode == 8)
BLYNK_LOG("Setting lights to moonrise mode based on current time...");
if(LEDStartMode == 9)
BLYNK_LOG("Setting lights to moonfall mode based on current time...");
LEDsettings[i].lastPWM = LEDsettings[i].moonPWM;
//calculate currentPWM based on where we are in ramp
LEDsettings[i].currentPWM = LEDsettings[i].lastPWM + ((difference * secondsIntoRamp) / fadeTimeSeconds);
LEDsettings[i].currentPWM = LEDsettings[i].lastPWM - ((difference * secondsIntoRamp) / fadeTimeSeconds);
//start a new ramp beginning at current time using time remaining of ramp
tempFadeTimeMillis = (fadeTimeSeconds - secondsIntoRamp)*1000;
LEDsettings[i].fadeIncrementTime = tempFadeTimeMillis / difference;
writeLEDs();
// returns scaling factor for current day in lunar cycle
byte lunarCycleScaling()
byte scaleFactor[] = {25,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100,
95,90,85,80,75,70,65,60,55,50,45,40,35,30};
tmElements_t fixedDate = {0,35,20,0,7,1,0};
long lp = 2551443;
time_t newMoonCycle = makeTime(fixedDate);
long phase = (now() - newMoonCycle) % lp;
long returnValue = ((phase / 86400) + 1);
return scaleFactor[returnValue];
// returns day in lunar cycle 0-29
byte getLunarCycleDay()
long lp = 2551443;
return returnValue;
// Digital clock display of the time
void clockDisplay()
if(isAM())sprintf(Time, "%d:%02d AM", hourFormat12() , minute());
if(isPM())sprintf(Time, "%d:%02d PM", hourFormat12() , minute());
Blynk.virtualWrite(V9, Time);
