Hey! I’m currently using an Arduino UNO with an esp8266 and this esp8266 adapter
and I’m trying to control servo motors via blynk. For now, I´m using code from a youtube tutorial which is proven to work. Although, when I’m booting up the Arduino with the provided code I get the error: esp not responding. When I control the esp8266 via AT commands through serial monitor I can connect to wifi and get IP. Therefore I’m assuming the esp8266 works fine with the following wirering. Do you guys have any ideas as to why this occurs?// Ekan
vcc adapter --> 5V arudino
rx adapter --> prin 0 arduino
tx adapter --> pin 1 arudino
ground adapter --> ground arduino
http://twitter.com/blynk_app
WARNING!
It's very tricky to get it working. Please read this article:
http://help.blynk.cc/hardware-and-libraries/arduino/esp8266-with-at-firmware
This example shows how value can be pushed from Arduino to
the Blynk App.
NOTE:
BlynkTimer provides SimpleTimer functionality:
http://playground.arduino.cc/Code/SimpleTimer
App project setup:
Value Display widget attached to Virtual Pin V5
#include <ESP8266_Lib.h>
#include <OneWire.h>
#include <Wire.h>
#define ONE_WIRE_BUS 38 //ds18b20 module attach to pin39
// Pass our oneWire reference to Dallas Temperature.
char auth[] = "secret.exe";
char ssid[] = "iPhone";
char pass[] = "frickoff";
//#define EspSerial Serial
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
void myTimerEvent()
void getTemp()
sensors.requestTemperatures(); // Send the command to get temperatures
Blynk.virtualWrite(V6, sensors.getTempCByIndex(0));
Serial.print("Tem: ");
Serial.println(sensors.getTempCByIndex(0));
sensors.begin(); // initialize the bus
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 8442);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8442);
timer.setInterval(6000L, getTemp);
