Esp8266 nodemcu x
Arduino: 1.8.9 (Windows 7), Board: “NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200”
C:\Users\hcc\AppData\Local\Temp\arduino_modified_sketch_697744\ESP8266_Standalone (2).ino:41:11: error: redefinition of 'char auth []'
ESP8266_Standalone:41:6: error: 'char auth [33]' previously defined here
 char auth[] = "4HXSGBbFaSP8trWNq2SWmZFKPJieUTKv";
C:\Users\hcc\AppData\Local\Temp\arduino_modified_sketch_697744\ESP8266_Standalone (2).ino:45:11: error: redefinition of 'char ssid []'
ESP8266_Standalone:45:6: error: 'char ssid [6]' previously defined here
 char ssid[] = "moudi";
C:\Users\hcc\AppData\Local\Temp\arduino_modified_sketch_697744\ESP8266_Standalone (2).ino:46:11: error: redefinition of 'char pass []'
 char pass[] = "YourPassword";
ESP8266_Standalone:46:6: error: 'char pass [12]' previously defined here
 char pass[] = "youkoko2010";
C:\Users\hcc\AppData\Local\Temp\arduino_modified_sketch_697744\ESP8266_Standalone (2).ino: In function 'void setup()':
C:\Users\hcc\AppData\Local\Temp\arduino_modified_sketch_697744\ESP8266_Standalone (2).ino:48:6: error: redefinition of 'void setup()'
ESP8266_Standalone:48:6: error: 'void setup()' previously defined here
C:\Users\hcc\AppData\Local\Temp\arduino_modified_sketch_697744\ESP8266_Standalone (2).ino: In function 'void loop()':
C:\Users\hcc\AppData\Local\Temp\arduino_modified_sketch_697744\ESP8266_Standalone (2).ino:56:6: error: redefinition of 'void loop()'
ESP8266_Standalone:56:6: error: 'void loop()' previously defined here
exit status 1
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  This example runs directly on ESP8266 chip.
  Please be sure to select the right ESP8266 module
  in the Tools -> Board menu!
char auth[] = "nkkjnkononhiubnnnnniun";
I’ve edited your post to add triple backticks at the beginning and g and end of your code, and your compiler output, so that they display correctly.
In future, please add these yourself or your code will be deleted.
I’ve also reclassified your post from “issues and errors” to “need help with my project”.
Issues and errors is used for bug reporting, this is not a bug.
Your compiler output doesn’t match your code. The compiler errors are saying that you have multiple declarations of variables and functions.
My advice would be to create a new sketch in the IDE, delete the few lines of code that are created automatically, paste the code from the sketch builder and edit that code to add-in your SSID, Wi-Fi password and Blynk Auth code.
You’ll need:
  • Blynk App (download from AppStore or Google Play)
  • ESP8266 board
  • Decide how to connect to Blynk
    (USB, Ethernet, Wi-Fi, Bluetooth, …)
example.
char auth[] = “4HXSGBbFaSP8trWNq2SWmZFKPJieUTKv”;
// Set password to “” for open networks.
char ssid[] = “moudi”;
char pass[] = “youkoko2010”;
//Blynk.begin(auth, ssid, pass, “blynk-cloud.com”, 80);
// to avoid delay() function!
___  __          __
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
//_, /////_
__/ v0.6.1 on NodeMCU
[6780] Connecting to blynk-cloud.com:80
[10049] Login timeout
[12049] Connecting to blynk-cloud.com:80
[15064] Login timeout
[17064] Connecting to blynk-cloud.com:80
[20146] Login timeout
[22146] Connecting to blynk-cloud.com:80
[27178] Connecting to blynk-cloud.com:80
[30189] Login timeout
[32189] Connecting to blynk-cloud.com:80
[37213] Connecting to blynk-cloud.com:80
[40233] Login timeout
[42233] Connecting to blynk-cloud.com:80
[47244] Connecting to blynk-cloud.com:80
[50263] Login timeout
[52263] Connecting to blynk-cloud.com:80
[55278] Login timeout
[57278] Connecting to blynk-cloud.com:80
[60296] Login timeout
[62296] Connecting to blynk-cloud.com:80
[65325] Login timeout
[67325] Connecting to blynk-cloud.com:80
[72343] Connecting to blynk-cloud.com:80
[75367] Login timeout
[77367] Connecting to blynk-cloud.com:80
[82385] Connecting to blynk-cloud.com:80
[85406] Login timeout
[87406] Connecting to blynk-cloud.com:80
[92438] Connecting to blynk-cloud.com:80
[95461] Login timeout
[97461] Connecting to blynk-cloud.com:80
[100483] Login timeout
[102483] Connecting to blynk-cloud.com:80
[105497] Login timeout
[107497] Connecting to blynk-cloud.com:80
[110515] Login timeout
[112515] Connecting to blynk-cloud.com:80
[117535] Connecting to blynk-cloud.com:80
[120563] Login timeout
[122563] Connecting to blynk-cloud.com:80
[128246] Connecting to blynk-cloud.com:80
[131367] Login timeout
what i should do tolet it work if there is something wrong can u please correct it for me
I’ve made your private message to me public. Please keep discussions of this type public so that all forum members can contribute to a solution.
Please edit your post above (the one that contains the code and the serial output) using the pencil icon at the bottom of the post, and add triple backticks at the beginning and end of both the code and the serial monitor output, so that they display correctly.
Triple backticks look like this (you can copy and past them if necessary):
Once you’ve done this I’ll point you in the right direction.
