Hello blynkers.
I have a problem when I synchronize my NodeMCU with my Blynk App. Basically I load the program correctly to the NodeMCU, but the Blynk App ignores that the NodeMCU is connected. I verify the program and the AuthToken is written correctly, also the internet ssid and pass. I try to load the program many times and the problem persist.
I’m using the NodeMCU with a YF-s201 flow sensor, also I’m using the most recent Blynk Library. Thank you in advance guys.
char auth[] = "xxxxxx";
char ssid[] = "xxxxxx";
char pass[] = "xxxxxx";
int sensor = A0;
int val = 0;
int Porcentaje = 0;
volatile int NumPulsos;
const int sensorPin= 14;
float factor_conversion=7.11;
float volumen=0;
long dt=0;
long t0=0;
byte sensorInterrupt = 0;
void ContarPulsos ()
NumPulsos++;
int ObtenerFrecuecia()
int frecuencia;
NumPulsos = 0;
interrupts();
noInterrupts();
frecuencia=NumPulsos;
return frecuencia;
void sendSensor()
val = analogRead(sensor);
Porcentaje = map(val, 1023, 0, 0, 100);
Blynk.virtualWrite(V0, Porcentaje);
void sendSensor3(){
float frecuencia=ObtenerFrecuecia();
float caudal_L_m=frecuencia/factor_conversion;
dt=millis()-t0;
t0=millis();
volumen=volumen+(caudal_L_m/60)*(dt/1000);
Blynk.virtualWrite(V6, caudal_L_m);
Blynk.virtualWrite(V7, volumen);
pinMode (sensor,INPUT);
pinMode (sensorPin,INPUT);
attachInterrupt(digitalPinToInterrupt(14), ContarPulsos,RISING);
t0=millis();
timer.setInterval(1010L, sendSensor3);
