#include <DHT.h>
const int buttonPin = 15; // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin
char auth[] = "c664ad5b69c2xxxxxxxxxxxxxxxxxxxx";
char ssid[] = "XXXX";
char pass[] = "XXXXXXXXXXXXX";
#define DHTPIN 2 // Conectar a D4 del ESP8266 ARDUINO
int buttonState = 0; // variable for reading the pushbutton status
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
dht.begin();
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (buttonState == HIGH) {
// turn LED on:
digitalWrite(ledPin, HIGH);
// turn LED off:
digitalWrite(ledPin, LOW);
You didn’t mention anything about what your project does/accomplishes and you forgot to format your posted code.
just blink LEDs
Humidity is 21% how anybody can achieve that , is the number actual reading or just for demonstration ?
Not because Arduino will burn ! with 500 ma
Demostration…
