Hi everyone, Now i try to connect my esp8266 to Blynk 2.0. After I upload the code, esp8266 do not show the same SSID name on the network. As you can see on the figure below, the correct SSID name is ‘‘Blynk Monitoring Energy Consumption-49F61’’, whereas show in network is ‘‘ESP-17D241’’.
Then i try to connect this network ‘‘ESP-17D241’’ in blynk app on my phone, but it fails.
I using Lolin new NodeMCU V3 microcontroller.
Here is my code.
#define BLYNK_TEMPLATE_ID "TMPLZxyDHzLA"
#define BLYNK_DEVICE_NAME "Monitoring Energy Consumption"
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_SPARKFUN_BLYNK_BOARD
#define USE_NODE_MCU_BOARD
//#define USE_WITTY_CLOUD_BOARD
//#define USE_WEMOS_D1_MINI
#include "BlynkEdgent.h"
#include "EmonLib.h"
EnergyMonitor emon1;
int PinA= A0; //sct pins
float Power;
double Current;
float Energy = 0;
float Voltage = 240;
double noise1 = 0.26; //0.26
double noise2 = 0.36; //0.36
unsigned long lastmillis=millis();
long prevMillis=0;
emon1.current(PinA, 100); // Current: input pin, calibration.
BlynkEdgent.begin();
delay (10000);
if (millis()-prevMillis>15000) // Every 5 seconds it measure the current
Current = emon1.calcIrms(5000); // Calculate Irms only=1480
double calcurrent=Current*0.7071;
if (noise1<calcurrent<noise2)
calcurrent=0;
Serial.print(calcurrent,4); // Irms
Serial.println("A");
Power = calcurrent*Voltage;
Serial.print(Power,4);
Serial.println("W");// Apparent power
Energy = Energy + Power*(millis()-lastmillis)/36000000000.0;
Serial.print(Energy,5);
Serial.println("kwh");
prevMillis=millis();
Serial.println(" ");
Blynk.virtualWrite(V0,calcurrent);
Blynk.virtualWrite(V1,Power);
Blynk.virtualWrite(V2,Energy);
BlynkEdgent.run();
