I really cannot think at a more simpler way to do a AC Dimmer than Blynk & MPDMv4. I am new to Blynk but I must say that I am really impressed how simple was the entire Project Setup process.
My Setup:
The Arduino IDE sketch code for using the MPDMv4 Dimmer is the one from below, nothing else necessary to run your AC Dimmer. Deadly simple!!
char auth[] = "add you key";
Blynk.begin(auth, "WIFI_SSID ", "passwd here");
On the Android phone that I used, in Blynk App, just created a new app & defined a new Slider in it, added desired PWM pin to it ( I have used GPIO5 ), defined slider values from 0->880 and that’s it.
Delightful
Soon also a Youtube Video with the Blynk MPDMv4 AC Dimmer Setup & software example will follow.
Happy Breadboarding,
TJ.
