Hi communtity !
I find old sketch for control DC motor with an L298 and ESP8266. i want to test it and i have this return during compilation :
Arduino : 1.8.16 (Windows 10), Carte : "Generic ESP8266 Module, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
sketch_sep26a:10:26: error: 'D1' was not declared in this scope; did you mean 'y1'?
10 | const byte L298N_A_pin = D1; // ENA for Ln298 motor drive
| y1
sketch_sep26a:11:30: error: 'D2' was not declared in this scope; did you mean 'V2'?
11 | const byte L298N_A_In1_pin = D2; // in1 for Ln298 motor drive
| V2
sketch_sep26a:12:30: error: 'D3' was not declared in this scope; did you mean 'V3'?
12 | const byte L298N_A_In2_pin = D3; // in2 for Ln298 motor drive
| V3
sketch_sep26a:13:30: error: 'D4' was not declared in this scope; did you mean 'V4'?
13 | const byte L298N_B_In3_pin = D4; // in3 for Ln298 motor drive
| V4
sketch_sep26a:14:30: error: 'D5' was not declared in this scope; did you mean 'V5'?
14 | const byte L298N_B_In4_pin = D5; // in4 for Ln298 motor drive
| V5
sketch_sep26a:15:26: error: 'D6' was not declared in this scope; did you mean 'V6'?
15 | const byte L298N_B_pin = D6; // ENB for Ln298 motor drive
| V6
exit status 1
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
For this sketch :
char auth[] = "xxxxxx"; //YourToken
char ssid[] = "xxxxxx"; //YourNetworkName
char pass[] = "xxxxxx"; //YourPassword
byte LeftTurnSignal = 0;
byte RightSignal = 0;
void motorSpeed(int prmA, byte prmA1, byte prmA2, int prmB, byte prmB1, byte prmB2)
analogWrite(L298N_A_pin,prmA);
analogWrite(L298N_B_pin,prmB);
digitalWrite(L298N_A_In1_pin,prmA1);
digitalWrite(L298N_A_In2_pin,prmA2);
digitalWrite(L298N_B_In3_pin,prmB1);
digitalWrite(L298N_B_In4_pin,prmB2);
BLYNK_WRITE(V1) {
int x = param[0].asInt();
int y = param[1].asInt();
// x = -10..-2 -1 0 1 2 ..10
// Y = -10..-2 -1 0 1 2 ..10
if ((x==0) && (y==0)) // stop
motorSpeed(0,LOW,LOW,0,LOW,LOW);
else if (((x>=-3) && (x<=3)) && (y>0)) // forward
if (y==1){ motorSpeed(100,HIGH,LOW,100,HIGH,LOW); }
else if (y==2){ motorSpeed(200,HIGH,LOW,200,HIGH,LOW); }
else if (y==3){ motorSpeed(300,HIGH,LOW,300,HIGH,LOW); }
else if (y==4){ motorSpeed(400,HIGH,LOW,400,HIGH,LOW); }
else if (y==5){ motorSpeed(500,HIGH,LOW,500,HIGH,LOW); }
else if (y==6){ motorSpeed(600,HIGH,LOW,600,HIGH,LOW); }
else if (y==7){ motorSpeed(700,HIGH,LOW,700,HIGH,LOW); }
else if (y==8){ motorSpeed(800,HIGH,LOW,800,HIGH,LOW); }
else if (y==9){ motorSpeed(900,HIGH,LOW,900,HIGH,LOW); }
else if (y==10){ motorSpeed(1000,HIGH,LOW,1000,HIGH,LOW); }
pinMode(L298N_A_In1_pin,OUTPUT);
pinMode(L298N_A_In2_pin,OUTPUT);
pinMode(L298N_B_In3_pin,OUTPUT);
pinMode(L298N_B_In4_pin,OUTPUT);
digitalWrite(L298N_A_In1_pin,LOW);
digitalWrite(L298N_A_In2_pin,LOW);
digitalWrite(L298N_B_In3_pin,LOW);
digitalWrite(L298N_B_In4_pin,LOW);
I have to name physical PIN with GPIO number ?
Thanks for help
