Hardware/Software used:
- NodeMCU ESP8266 Module
- Blynk version: 1.2.0
- ESP Library version: 3.1.1
Hi, I am using this “weather station” code that I did a while ago, and it used to work just fine on the old blynk app. Since it is now discontinued I needed to rebuild this project for the new blynk environment. But I am having infinite reboots caused by the interrupts definition. I determined that if I take out these two lines of code the issue goes away. Does somebody know what might be causing this issue?
attachInterrupt(digitalPinToInterrupt(reed_switch_pin_pluviometro), callbackPluviometro, FALLING);
attachInterrupt(digitalPinToInterrupt(reed_switch_pin_anemometro), callbackAnemometro, FALLING);
I enter on a re-boot loop and the error message says something like this:
10:55:59.916 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
10:55:59.949 ->
10:55:59.949 -> ets Jan 8 2013,rst cause:2, boot mode:(3,7)
10:55:59.949 ->
10:55:59.949 -> load 0x4010f000, len 3424, room 16
10:55:59.949 -> tail 0
10:55:59.949 -> chksum 0x2e
10:55:59.949 -> load 0x3fff20b8, len 40, room 8
10:55:59.949 -> chksum 0x2b
10:55:59.949 -> csum 0x2b
10:55:59.949 -> v00048650
10:55:59.949 -> ~ld
10:56:00.029 -> ISR not in IRAM!
10:56:00.029 ->
10:56:00.029 -> User exception (panic/abort/assert)
10:56:00.029 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
10:56:00.029 ->
10:56:00.029 -> Abort called
10:56:00.029 ->
10:56:00.029 -> >>>stack>>>
10:56:00.029 ->
10:56:00.029 -> ctx: cont
10:56:00.029 -> sp: 3fffff00 end: 3fffffd0 offset: 0000
10:56:00.029 -> 3fffff00: 3ffeffbc 00000020 3fffff70 3ffeffbc
10:56:00.029 -> 3fffff10: 000000fe 00000000 00000000 00000000
10:56:00.064 -> 3fffff20: 00000000 00000000 00000000 402071ba
10:56:00.064 -> 3fffff30: 3fffefd0 000000fe 00000000 00ff0000
10:56:00.064 -> 3fffff40: 5ffffe00 5ffffe00 ffffffff 3ffef060
10:56:00.064 -> 3fffff50: 00000000 00000002 0000000e 40206322
10:56:00.064 -> 3fffff60: 4010055d 00000001 3ffeeed8 40206334
10:56:00.064 -> 3fffff70: 00000000 0012001f 0000000e 40206825
10:56:00.064 -> 3fffff80: 0001c200 0000001c 00000000 40206428
10:56:00.104 -> 3fffff90: 3fffdad0 00000000 3ffef034 4020257e
10:56:00.104 -> 3fffffa0: feefeffe feefeffe feefeffe feefeffe
10:56:00.104 -> 3fffffb0: feefeffe feefeffe feefeffe 40205e8c
10:56:00.104 -> 3fffffc0: feefeffe feefeffe 3fffdab0 40100f91
10:56:00.104 -> <<<stack<<<
10:56:00.104 ->
10:56:00.104 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
// BLYNK -> V4 (lluvia en milimetros)
// -> V5 (lluvia en milimetros dividido 3)
// -> V6 (anemometro promedio 10secs)
// -> V0 (reseteo de lluvia)
// -> V1 (fecha de reseteo lluvia)
// -> V2 (anemometro)
#define BLYNK_TEMPLATE_ID "THASH"
#define BLYNK_TEMPLATE_NAME "T1"
#define BLYNK_AUTH_TOKEN "TKN"
#define EEPROM_SIZE 512
#include <EEPROM.h>
#include "Time.h"
#include <NTPtimeESP.h>
//** SENSOR PINS
const int reed_switch_pin_pluviometro = 14; // GPI014, D5
const int reed_switch_pin_anemometro = 12; // GPIO12, D6
//** DIRECCIONES EEPROM STORAGE
const int eeDir_contador = 100;
const int eeDir_lluvia_milimetros = 150;
const int eeDir_lluvia_milimetros_div3 = 250;
const int eeDir_fecha_reset = 200;
const float rev_rad_conv = 6.28;
const float radio_anemometro = 0.06; // en metros (son 6cm)
const int milimetros_por_cuenta = 1;
// Define NTP Client to get time
NTPtime NTPch("pool.ntp.org");
char ssid[] = "ssid"; //local wifi network SSID
char pass[] = "passwd"; //local network password
BlynkTimer timer; //config timer
// anemometro variables
int contador_pluviometro = 0;
float lluvia_milimetros = 0;
float lluvia_milimetros_div3 = 0;
// pluviometro variables
int contador_anemometro = 0;
float velocidad_viento = 0;
float velocidad_viento_promedio = 0;
float contador_medicion_viento = 0;
bool procesar_pluviometro = false;
void procesarLluvia() {
contador_pluviometro += 1;
lluvia_milimetros = milimetros_por_cuenta * contador_pluviometro;
lluvia_milimetros_div3 = int(milimetros_por_cuenta * contador_pluviometro / 3);
grabarEeprom(eeDir_contador, contador_pluviometro);
grabarEeprom(eeDir_lluvia_milimetros, lluvia_milimetros);
Blynk.virtualWrite(V4, lluvia_milimetros);
Blynk.virtualWrite(V5, lluvia_milimetros_div3);
void procesarViento() {
contador_medicion_viento += 1;
velocidad_viento_promedio = (velocidad_viento_promedio + velocidad_viento) / contador_medicion_viento; // para pasar a km/h
velocidad_viento = contador_anemometro * rev_rad_conv * radio_anemometro; // en m/s
velocidad_viento = velocidad_viento * 3.6; // para pasar a km/h
if (contador_medicion_viento >= 10) {
Blynk.virtualWrite(V2, velocidad_viento);
Blynk.virtualWrite(V6, velocidad_viento_promedio);
EEPROM.begin(EEPROM_SIZE);
iniciarEeprom();
// interrupts
pinMode(reed_switch_pin_pluviometro, INPUT_PULLUP);
pinMode(reed_switch_pin_anemometro, INPUT_PULLUP);
timer.setInterval(1000, procesarViento);
printWifiStatus();
void printWifiStatus() {
Serial.println();
Serial.println("Connecting to " + String(ssid)); // Connected to WiFi network
delay(20);
Serial.println(WiFi.localIP()); //this is local IP for this board
void callbackPluviometro() {
Serial.println("llamo lluvia");
procesar_pluviometro = true;
void callbackAnemometro() {
Serial.println("llamo anemometro");
contador_anemometro += 1;
if (procesar_pluviometro) {
procesarLluvia();
// HELPER FUNCTIONS AND BLYNK TERMINAL
// PARA PODER RESETEAR LA LLUVIA
BLYNK_WRITE(V0) {
int state = param.asInt();
strDateTime dateTime = NTPch.getNTPtime(-3.0, 0);
if (state == 1)
grabarEeprom(eeDir_lluvia_milimetros_div3, lluvia_milimetros);
Blynk.virtualWrite(V5, lluvia_milimetros);
do {
Serial.println("entro al dowhile");
delay(50);
} while (!dateTime.valid);
if (dateTime.valid) {
String now = String(dateTime.day) + "/" + \
String(dateTime.month) + "/" + \
String(dateTime.year) + " " + \
String(dateTime.hour) + ":" + String(dateTime.minute) + ":" + String(dateTime.second);
Serial.println(now);
writeStringToEEPROM(eeDir_fecha_reset, now);
Blynk.virtualWrite(V1, now);
void iniciarEeprom() {
int valor;
int lluvia_milimetros_lo = EEPROM.read(eeDir_lluvia_milimetros);
int lluvia_milimetros_hi = EEPROM.read(eeDir_lluvia_milimetros+1);
valor = (lluvia_milimetros_hi << 8) | lluvia_milimetros_lo;
lluvia_milimetros = valor;
int valor_div3;
int lluvia_milimetros_lo_div3 = EEPROM.read(eeDir_lluvia_milimetros_div3);
int lluvia_milimetros_hi_div3 = EEPROM.read(eeDir_lluvia_milimetros_div3+1);
valor_div3 = (lluvia_milimetros_hi_div3 << 8) | lluvia_milimetros_lo_div3;
lluvia_milimetros_div3 = valor_div3;
int contador_lo = EEPROM.read(eeDir_contador);
int contador_hi = EEPROM.read(eeDir_contador+1);
valor = (contador_hi << 8) | contador_lo;
contador_pluviometro = valor;
String now = readStringFromEEPROM(eeDir_fecha_reset);
void grabarEeprom(int dir, int val) {
byte val_lo = val; // It automatically stores the lower bits of x
byte val_hi = val >> 8; // It stores the upper bits of x
EEPROM.write(dir, val_lo);
EEPROM.write(dir+1, val_hi);
EEPROM.commit();
void writeStringToEEPROM(int addrOffset, const String &strToWrite) {
byte len = strToWrite.length();
EEPROM.write(addrOffset, len);
for (int i = 0; i < len; i++)
EEPROM.write(addrOffset + 1 + i, strToWrite[i]);
EEPROM.commit();
String readStringFromEEPROM(int addrOffset) {
int newStrLen = EEPROM.read(addrOffset);
char data[newStrLen + 1];
for (int i = 0; i < newStrLen; i++)
data[i] = EEPROM.read(addrOffset + 1 + i);
data[newStrLen] = '\0'; // !!! NOTE !!! Remove the space between the slash "/" and "0" (I've added a space because otherwise there is a display bug)
return String(data);
