hello:
using WeMOS-D1 mini, I made a small project with 5 outputs, 4 digital inputs and one analog input.
it run OK with digital widgets. when I add “labeled value” for analog input I got “device was disconnected” and communication stops
Any help is appreciated.
My program:
* Downloads, docs, tutorials: http://www.blynk.cc
* Blynk community: http://community.blynk.cc
* Social networks: http://www.fb.com/blynkapp
* http://twitter.com/blynk_app
* This example runs directly on ESP8266 chip.
* You need to install this for ESP8266 development:
* https://github.com/esp8266/Arduino
* Please be sure to select the right ESP8266 module
* in the Tools -> Board menu!
* Change WiFi ssid, pass, and Blynk auth token to run :)
#include <EEPROM.h>
//EEPROM.read(address)
//EEPROM.write(address, value)
char str[20],x0,x1;
char auth[] = "813b9989d77c464ebd16b33d2da0b5e0";
EEPROM.begin(4);
digitalWrite(0,LOW);
digitalWrite(2,LOW);
digitalWrite(4,LOW);
digitalWrite(5,LOW);
digitalWrite(15,LOW);
pinMode(5,OUTPUT);
pinMode(4,OUTPUT);
pinMode(0,OUTPUT);
pinMode(2,OUTPUT);
pinMode(15,OUTPUT);
Blynk.begin(auth, "Morosh", "94034690");
//Blynk.email("morisaab@yahoo.fr", "Subject: Motion Detected", "Suspicious activiy detected!!...");
if(EEPROM.read(0)==255) {EEPROM.write(0,0);EEPROM.commit();}
x0=EEPROM.read(0);
digitalWrite(0,bitRead(x0,0));
digitalWrite(2,bitRead(x0,1));
digitalWrite(4,bitRead(x0,2));
digitalWrite(5,bitRead(x0,3));
digitalWrite(15,bitRead(x0,4));
x1=x0;
long x;
x=analogRead(0)*330/1023;
sprintf(str,"temp=%u °C",x);
Blynk.virtualWrite(V0, str);
if(digitalRead(0)==LOW) Blynk.virtualWrite(V1, 0); else Blynk.virtualWrite(V1, 255);
if(digitalRead(2)==LOW) Blynk.virtualWrite(V2, 0); else Blynk.virtualWrite(V2, 255);
if(digitalRead(4)==LOW) Blynk.virtualWrite(V3, 0); else Blynk.virtualWrite(V3, 255);
if(digitalRead(5)==LOW) Blynk.virtualWrite(V4, 0); else Blynk.virtualWrite(V4, 255);
if(digitalRead(15)==LOW) Blynk.virtualWrite(V5, 0); else Blynk.virtualWrite(V5, 255);
if(digitalRead(16)==HIGH) Blynk.virtualWrite(V6, 0); else Blynk.virtualWrite(V6, 255);
if(digitalRead(14)==HIGH) Blynk.virtualWrite(V7, 0); else Blynk.virtualWrite(V7, 255);
if(digitalRead(12)==HIGH) Blynk.virtualWrite(V8, 0); else Blynk.virtualWrite(V8, 255);
if(digitalRead(13)==HIGH) Blynk.virtualWrite(V9, 0); else Blynk.virtualWrite(V9, 255);
bitWrite(x1, 0, digitalRead(0));
bitWrite(x1, 1, digitalRead(2));
bitWrite(x1, 2, digitalRead(4));
bitWrite(x1, 3, digitalRead(5));
bitWrite(x1, 4, digitalRead(15));
if(x1!=x0) {EEPROM.write(0,x1); EEPROM.commit(); x0=x1;}
VERY IMPORTANT: You can’t send sensor data in your void loop()
gazillion number of times. Which means that Blynk Cloud will be flooded with gazillion messages from your hardware.
︎ cuts your connection. Sorry…
