Local server on RPI2
Module NodeMCU v3
Sketch arduino ide
The module does not connect to the server, instead it breaks into the Internet.
Arduino writes: Connecting to blynk-cloud.com:80 messages are repeated.
I tried with different ports 8080, 9442.9443.
I found a similar problem, but it is not clear where to replace the address with my own ( (SOLVED) Connect to local blynk server on raspberry) .
please, help
here’s a sketch:
//My GitHub https://github.com/manoranjan2050
//My Hackster.io https://www.hackster.io/Manoranjan2050
//This Video Link https://youtu.be/0dbws1i2GoE
#include <DHT.h>
char auth[] = "4258890441574e08b7dde8ec975730b3";
char ssid[] = "TU";
char pass[] = "sdf";
char server[] = "192.168.1.38"; // The local IP address of your Local Server device.
#define DHTPIN 2 // D2
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V1, t);
Blynk.virtualWrite(V2, h);
//Blynk.begin(auth, ssid, pass, 192,168,1,38, 9442);
Blynk.begin(auth, ssid, pass, server, 9443);
dht.begin();
