ESP8266 DHT11 relay notification problem
Hello
I want to the values ​​to be read from the dht11 sensor every 10 seconds. When the notification comes, I want to my next notification to come after 5 minutes. Can you check my code?
#include <timer.h>
#include <dht11.h> // dht11 kütüphanesini ekliyoruz.
#define DHT11PIN 4 // DHT11PIN olarak Dijital 2"yi belirliyoruz.
dht11 DHT11;
int sicaklik, nem;
Timer timer;
// OKUNABİLİR VERİLER
// SICAKLIK     - DHT11.temperature
// NEM          - DHT11.humidity
// ÇİĞ NOKTASI  - DHT11.fahrenheit()
// KELVİN       - DHT11.kelvin()
// ÇİĞ NOKTASI  - DHT11.dewPoint()
char auth[33] = "";
char ssid[33] = "";
char pass[33] = "";
BLYNK_READ(V0){
  DHT11.read(DHT11PIN);
  sicaklik = DHT11.temperature;
  Serial.println("Sıcaklık: " + String(sicaklik));
  Blynk.virtualWrite(V0, sicaklik);
BLYNK_READ(V1) {
  nem = DHT11.humidity;
  Serial.println("Nem: " + String(nem));
  Blynk.virtualWrite(V1, nem);
  sicaklik_alert();
  nem_alert();
void sicaklik_alert(){
  delay(15000);
  if(sicaklik > 28)
    Blynk.notify(String("Sıcaklık Yüksek ")+sicaklik + String("°C"));
  if(sicaklik > 28)
    Blynk.email("mail address", String("Sıcaklık Yüksek ")+sicaklik + String("°C"));
  if(sicaklik < 21)
    Blynk.notify(String("Sıcaklık Düşük ")+sicaklik + String("°C"));
  if(sicaklik < 21)
    Blynk.email("mail address", String("Sıcaklık Düşük ")+sicaklik + String("°C"));
void nem_alert(){
if(nem > 85)
    Blynk.email("mail address", String("Nem Yüksek  ")+nem + String(" RH"));
if(nem < 50)
    Blynk.email("mail address", String("Nem Düşük  ")+nem + String(" RH"));
if(nem > 85)
    Blynk.notify(String("Nem Yüksek  ")+nem + String(" RH"));
if(nem < 50)
   Blynk.notify(String("Nem Düşük  ")+nem + String(" RH"));
@Adem_Akbulut please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Thank you edited my post
You should start by reading this…
https://docs.blynk.io/en/legacy-platform/legacy-articles/keep-your-void-loop-clean
and getting rid of the delays and the function calls in your void loop, and using a BlynkTimer instead.
Thank you for your support.
I solved my problem by changing my code as below.
#include <DHT.h>
char auth[] = "";
char ssid[] = "";
char pass[] = "";
#define DHTPIN 4          // What digital pin we're connected to
#define DHTTYPE DHT11     // DHT 11
//#define DHTTYPE DHT22   // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21   // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
 float nem = dht.readHumidity();
 float sicaklik = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
 if (isnan(nem) || isnan(sicaklik)) {
   return;
void sendAlert()
  if(sicaklik > 26)
 //Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
 dht.begin();
 timer.setInterval(5000L, sendSensor);
 timer.setInterval(60000L, sendAlert);
