Hi, I have troubles with this code. I can’t figure out what is wrong with it and why the esp8266 device appears offline in blynk app even in the serial monitor all details are good. Can someone please help me with this?
//_______________________OTABlynkCredentials.ini________________
#include "OTABlynkCredentials.h"
#ifdef ESP8266
#elif defined(ESP32)
#include <BlynkSimpleEsp32.h>
#else
#error "Board not found"
#endif
credentials Credentials;
//Variables
char auth_token[33];
bool connected_to_internet = 0;
const int Erasing_button = 0;
//Provide credentials for your ESP server
char* esp_ssid = "techiesms";
char* esp_pass = "";
BLYNK_WRITE(V0)
if(param.asInt()==1){
Blynk.virtualWrite(V0,HIGH);
else{
Blynk.virtualWrite(V0,LOW);
BLYNK_CONNECTED()
Blynk.syncVirtual(V0);
pinMode(Erasing_button, INPUT);
for (uint8_t t = 4; t > 0; t--) {
Serial.println(t);
// Press and hold the button to erase all the credentials
if (digitalRead(Erasing_button) == LOW)
Credentials.Erase_eeprom();
String auth_string = Credentials.EEPROM_Config();
auth_string.toCharArray(auth_token, 33);
if (Credentials.credentials_get())
Blynk.config(auth_token);
connected_to_internet = 1;
Credentials.setupAP(esp_ssid, esp_pass);
if (connected_to_internet)
pinMode(2, OUTPUT); // Initialise digital pin 2 as an output pin
delay(100);
Credentials.server_loops();
//____________________OTABlynkCredentials.h________________
* file OTABlynkCredentials.h
* This code is made for entering WiFi and Blynk Credentials
* Over the Air using your web browser.
* Written by Sachin Soni for techiesms YouTube channel, with
* contributions from the open source community.
*Visit our channel for more interesting projects
*https://www.youtube.com/techiesms
#ifdef ESP8266
#include <WiFi.h>
#else
#endif
#include "Arduino.h"
#include <ESPAsyncWebServer.h>
#include <WebSocketsServer.h>
#include <ArduinoJson.h>
#include <EEPROM.h>
class credentials {
public:
bool credentials_get();
void setupAP(char* softap_ssid, char* softap_pass);
void server_loops();
String EEPROM_Config();
void Erase_eeprom();
private:
bool _testWifi(void);
void _launchWeb(void);
void _createWebServer(void);
String ssid = "";
String pass = "";
//____________________OTABlynkCredentials.cpp___________________
AsyncWebServer server(80); // Creating WebServer at port 80
WebSocketsServer webSocket = WebSocketsServer(81); // Creating WebSocket Server at port81
// This is the webpage which is hosted on your ESP board
// and you can access this webpage by going to this address
// 192.168.4.1
char _webpage[] PROGMEM = R"=====(
<html>
<head>
<script>
var connection = new WebSocket('ws://'+location.hostname+':81/');
connection.onopen = function ()
connection.send('Connect ' + new Date()); };
connection.onerror = function (error)
console.log('WebSocket Error ', error);
connection.onmessage = function (e)
console.log('Server: ', e.data);
function credentials_rec()
var ssid = document.getElementById('ssid_cred').value;
var pass = document.getElementById('pass_cred').value;
var auth = document.getElementById('auth_token').value;
var full_command = '#{"ssid":"'+ ssid +'", "pass":"' +pass +'","auth":"'+ auth +'"}';
console.log(full_command);
connection.send(full_command);
location.replace('http://'+location.hostname+'/submit');
</script
</head>
<body>
<label for="ssid_cred">SSID Name:</label>
<input type="text" id="ssid_cred"><br><br>
<label for="pass_cred">Password:</label>
<input type="text" id="pass_cred"><br><br>
<lable for="auth_token">Auth Token:</label>
<input type="text" id="auth_token"><br><br>
<button type="button" onclick=credentials_rec();>Submit</button>
</body>
</html>
void _webSocketEvent(uint8_t num, WStype_t type, uint8_t * payload, size_t length)
switch (type) {
case WStype_DISCONNECTED:
Serial.printf("[%u] Disconnected!\n", num);
break;
case WStype_CONNECTED: {
IPAddress ip = webSocket.remoteIP(num);
Serial.printf("[%u] Connected from %d.%d.%d.%d url: %s\n", num, ip[0], ip[1], ip[2], ip[3], payload);
// send message to client
webSocket.sendTXT(num, "Connected");
break;
case WStype_TEXT:
Serial.printf("[%u] get Text: %s\n", num, payload);
if (payload[0] == '#')
String message = String((char*)( payload));
message = message.substring(1);
Serial.println(message);
//JSON part
DynamicJsonDocument doc(1024);
DeserializationError error = deserializeJson(doc, message);
String ssid = doc["ssid"];
String pass = doc["pass"];
String auth = doc["auth"];
Serial.println(ssid); Serial.println(pass);
// Clearing EEPROM
if (ssid.length() > 0 && pass.length() > 0) {
Serial.println("clearing eeprom");
for (int i = 0; i < 100; ++i) {
EEPROM.write(i, 0);
// Storing in EEPROM
Serial.println("writing eeprom ssid:");
for (int i = 0; i < ssid.length(); ++i)
EEPROM.write(i, ssid[i]);
Serial.print("Wrote: ");
Serial.println(ssid[i]);
Serial.println("writing eeprom pass:");
for (int i = 0; i < pass.length(); ++i)
EEPROM.write(32 + i, pass[i]);
Serial.println(pass[i]);
Serial.println("writing eeprom auth token:");
for (int i = 0; i < auth.length(); ++i)
EEPROM.write(64 + i, auth[i]);
Serial.println(auth[i]);
EEPROM.commit();
delay(2000);
//Restarting ESP board
ESP.restart();
break;
void credentials::Erase_eeprom()
EEPROM.begin(512); //Initialasing EEPROM
Serial.println("Erasing...");
EEPROM.write(i, 0);
EEPROM.commit();
String credentials::EEPROM_Config()
Serial.println();
Serial.println();
//---------------------------------------- Read eeprom for ssid and pass
Serial.println("Reading EEPROM");
for (int i = 0; i < 32; ++i)
ssid += char(EEPROM.read(i));
Serial.print("SSID: ");
for (int i = 32; i < 64; ++i)
pass += char(EEPROM.read(i));
Serial.print("Password: ");
String auth_token = "";
for (int i = 64; i < 100; ++i)
auth_token += char(EEPROM.read(i));
Serial.print("Auth Token: ");
Serial.println(auth_token);
return auth_token;
bool credentials::credentials_get()
if (_testWifi())
Serial.println("Succesfully Connected!!!");
return true;
Serial.println("Turning the HotSpot On");
return false;
void credentials::setupAP(char* softap_ssid, char* softap_pass)
WiFi.disconnect();
delay(100);
WiFi.softAP(softap_ssid,softap_pass);
Serial.println("softap");
_launchWeb();
Serial.println("Server Started");
webSocket.begin();
webSocket.onEvent(_webSocketEvent);
bool credentials::_testWifi()
int c = 0;
Serial.println("Waiting for Wifi to connect");
char* my_ssid = &ssid[0];
char* my_pass = &pass[0];
WiFi.begin(my_ssid, my_pass);
while ( c < 20 ) {
if (WiFi.status() == WL_CONNECTED)
return true;
delay(500);
Serial.print("*");
c++;
Serial.println("");
Serial.println("Connect timed out, opening AP");
return false;
// This is the function which will be called when an invalid page is called from client
void notFound(AsyncWebServerRequest *request)
request->send(404, "text/plain", "Not found");
void credentials::_createWebServer()
server.on("/", [](AsyncWebServerRequest * request) {
request->send_P(200, "text/html", _webpage);
// Send a GET request to <IP>/get?message=<message>
server.on("/submit", HTTP_GET, [] (AsyncWebServerRequest * request) {
String message;
message = "Credentials received by ESP board!!!";
request->send(200, "text/plain", message);
server.onNotFound(notFound);
server.begin();
void credentials::_launchWeb()
Serial.println("");
Serial.print("SoftAP IP: ");
Serial.println(WiFi.softAPIP());
_createWebServer();
// Start the server
void credentials::server_loops()
webSocket.loop();
