Hi, I am doing a project using the ESP 8266 as a Sheild with the Arduino Uno. I am following the Blynk Docs Tutorial to connect it. After Setting the Baud Rate to 9600 and connecting the TX and RX pins in the Serial Monitor I got.
As you can see I get that the ESP is connected but I don’t get Ready and the App still shows as not connected. What can I do? I am using a 3.3V Regulator so I don’t think it is a Power Supply Issue. The Only Questionable thing is that I am using a breadboard to connect everything.
Has anyone ever got this error or is it just me. I am also using the 1.5.4 Firmware for the ESP-01. I also tried the same ESP as Standalone and it worked. This is the code I am using. What should I try next?
http://twitter.com/blynk_app
This example shows how to use ESP8266 Shield (with AT commands)
to connect your project to Blynk.
WARNING!
It's very tricky to get it working. Please read this article:
http://help.blynk.cc/hardware-and-libraries/arduino/esp8266-with-at-firmware
#include <ESP8266_Lib.h>
char auth[] = "807ujcxxxxxxxxxxxxxxxxxxxxxxxxxx3f01";
char ssid[] = "Cxxxxxxxxxxxxxxxi";
char pass[] = "cxxxxxxxxxxxxxxi";
//#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
// Set ESP8266 baud rate
