Dear Sirs,
I have everything updated and I use ESP8266 Arduino Core master from github.
When I trying to compile any sketch that has cpp #include <TimeLib.h>
then I get errors.
Even the simple RTC sketch from sketch builder is not error free… See the sketch:
http://twitter.com/blynk_app
Blynk can provide your device with time data, like an RTC.
Please note that the accuracy of this method is up to several seconds.
App project setup:
RTC widget (no pin required)
Value Display widget on V1
Value Display widget on V2
WARNING :
For this example you'll need Time keeping library:
https://github.com/PaulStoffregen/Time
This code is based on an example from the Time library:
https://github.com/PaulStoffregen/Time/blob/master/examples/TimeSerial/TimeSerial.ino
#include <WidgetRTC.h>
char pass[] = "YourPassword";
WidgetRTC rtc;
// Digital clock display of the time
void clockDisplay()
// You can call hour(), minute(), ... at any time
// Please see Time library examples for details
Serial.print(currentTime);
Serial.print(" ");
Serial.print(currentDate);
Serial.println();
// Send time to the App
Blynk.virtualWrite(V1, currentTime);
// Send date to the App
Blynk.virtualWrite(V2, currentDate);
// Begin synchronizing time
rtc.begin();
// Other Time library functions can be used, like:
// timeStatus(), setSyncInterval(interval)...
// Read more: http://www.pjrc.com/teensy/td_libs_Time.html
// Display digital clock every 10 seconds
timer.setInterval(10000L, clockDisplay);
I got the errors:
In file included from E:\ARDUINO_ESP_DEV\arduino-IDE\hardware\esp8266com\esp8266/tools/sdk/libc/xtensa-lx106-elf/include/string.h:163:0,
from E:\ARDUINO_ESP_DEV\arduino-IDE\portable\sketchbook\libraries\Time\DateStrings.cpp:22:
E:\ARDUINO_ESP_DEV\arduino-IDE\hardware\esp8266com\esp8266/tools/sdk/libc/xtensa-lx106-elf/include/sys/string.h:32:0: warning: “strcpy_P” redefined [enabled by default]
#define strcpy_P(dest, src) strncpy_P((dest), (src), SIZE_IRRELEVANT)
E:\ARDUINO_ESP_DEV\arduino-IDE\portable\sketchbook\libraries\Time\DateStrings.cpp:20:0: note: this is the location of the previous definition
#define strcpy_P(dest, src) strcpy((dest), (src))
Why? Please try to sort this out…
Best Regards,
Mike Kranidis
