Hi, i have a problem with my project, when i have to write something in the virtual pins it didn’t work an also sometimes the connction with the wifi restart and disconnect the arduino from the wifi.
http://twitter.com/blynk_app
WARNING!
It's very tricky to get it working. Please read this article:
http://help.blynk.cc/hardware-and-libraries/arduino/esp8266-with-at-firmware
This example shows how value can be pushed from Arduino to
the Blynk App.
NOTE:
BlynkTimer provides SimpleTimer functionality:
http://playground.arduino.cc/Code/SimpleTimer
App project setup:
Value Display widget attached to Virtual Pin V5
#include <ESP8266_Lib.h>
char auth[] = "";
char ssid[] = "";
char pass[] = "";
//#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
void myTimerEvent()
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 80);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
this is my sketch
the hardware is arduino uno and esp8266
