Hi dear Blynkers,
I’m new here and I need help for my project.
I use ESP8266 as a weather and control station for my plants, which actually works quite well.
The ESP8266 will later be battery operated and would add a sleep mode in the following zenario:
1- Between 06:00 and 22:00 o’clock he should send values to blynk every hour and then go into deep sleep mode.
2- between 22:00 and 06:00 o’clock he should go deep sleep mode the whole time
Thank you
Here my code
#include "DHT.h"
#define DHTPIN D3
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
#define soilMoisterPin A0
#define soilMoisterVcc D8
char auth[] = "auth"; //
char ssid[] = "ssid";
char pass[] = "pass";
pinMode(soilMoisterVcc, OUTPUT);
digitalWrite (soilMoisterVcc, LOW);
Blynk.begin(auth, ssid, pass, IPAddress());
timer.setInterval(2000, getDHT);
timer.setInterval(2000, getSoilMoister);
void getDHT(void)
float airTemp = dht.readTemperature();
float airHum = dht.readHumidity();
if (isnan(airHum) || isnan(airTemp)) // Check if any reads failed and exit early (to try again).
return;
Blynk.virtualWrite(1, airTemp); //
Blynk.virtualWrite(2, airHum); //
void getSoilMoister(void)
int soilMoister = 0;
digitalWrite (soilMoisterVcc, HIGH);
delay (500);
int N = 3;
for(int i = 0; i < N; i++) // read sensor "N" times and get the average
soilMoister += analogRead(soilMoisterPin);
delay(150);
soilMoister = soilMoister/N;
soilMoister = map(soilMoister, 1024, 520, 0, 100);
Blynk.virtualWrite(3, soilMoister);
