Hi Guys
Once again I need help from minds greater than mine
I was having problems with my ESP8266_01 and I uploaded the sketch fro Arduino IDE
The CheckFlashConfig on the attachment is part of the error message I received from within the serial monitor
You have goofed something during the flash. The 01 is generally only used with an AT firmware, so as to work as an Arduino shield with Blynk… have you tried Googling your error?
Just use DOUT instead of DIO for ESP01, every flash will be successful this way. Even ESP01 can be used in stand alone mode with Blynk without any problems.
