hello! i’ve got a problem, i see a tutorial on instructables but it only works for Macbook.
this tutorial is about esp8266 programmation throught arduino board without usb/ttl converter.
how can i use this tutorial with windows?
thanks
thanks
Everything should be the same except for steps involving flashing the esp8266 (anything involving the terminal). The firmware is the same though. You just need to find a tutorial for flashing an esp using Windows (there are a lot in YouTube)
I personally like this one:
http://www.xess.com/blog/esp8266-reflash/
And if you have a bit more time on your hands and your flashing works, then try this for automated flashing without pulling pins high/low:
