I cant get this to connect to blynk online. It’s strange, I did at one point when I first created the project, I had my water drop sensor updating on the website. Went back a few days later and it doesn’t connect anymore. I tried new auth token, disconnecting power sources like sensors, and switching code like the port 80 to 8080 and different positions of Blynk.begin(). Am I missing something or is it my esp32 Wroom device? I also put some of the blynk.virtualwrite in the void loop would that have blocked my device?
I put my device information here:
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32dev.html
PLATFORM: Espressif 32 (6.6.0) > Espressif ESP32 Dev Module
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
- framework-arduinoespressif32 @ 3.20014.231204 (2.0.14)
- tool-esptoolpy @ 1.40501.0 (4.5.1)
- tool-mkfatfs @ 2.0.1
- tool-mklittlefs @ 1.203.210628 (2.3)
- tool-mkspiffs @ 2.230.0 (2.30)
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 37 compatible libraries
Scanning dependencies...
Dependency Graph
|-- OneWire @ 2.3.8
|-- DallasTemperature @ 3.11.0
|-- Blynk @ 1.3.2
|-- ESP32 Async UDP @ 2.0.0
|-- Preferences @ 2.0.0
|-- WebServer @ 2.0.0
|-- WiFi @ 2.0.0
; Please visit documentation for the other options and examples
; https://docs.platformio.org/page/projectconf.html
[env:upesy_wroom]
platform = espressif32
board = esp32dev
framework = arduino
monitor_speed = 115200
lib_deps =
OneWire
DallasTemperature
Blynk
Console output
Access Point Started
AP IP Address:
192.168.4.1
Attempting to connect to SSID: The LAN before Time
Connected to Wi-Fi!
Connected to Blynk!
IP Address: 192.168.0.238
SoftAP disconnected.
Flow rate: 0.00 L/min
Number of devices found on bus: 0
No devices found
Digital Output: 0, Analog Output: 117
[7306] Connecting to 0.0.0.0
[ 25577][E][WiFiClient.cpp:275] connect(): socket error on fd 49, errno: 113, "Software caused connection abort"
No devices found
Digital Output: 0, Analog Output: 0
[30593] Connecting to 0.0.0.0
[ 49113][E][WiFiClient.cpp:275] connect(): socket error on fd 49, errno: 113, "Software caused connection abort"
No devices found
Digital Output: 0, Analog Output: 2
[54128] Connecting to 0.0.0.0
[ 72648][E][WiFiClient.cpp:275] connect(): socket error on fd 49, errno: 113, "Software caused connection abort"
No devices found
[77663] Connecting to 0.0.0.0
[ 96183][E][WiFiClient.cpp:275] connect(): socket error on fd 49, errno: 113, "Software caused connection abort"
F
// Created by Jacob Lamkey
#include <Arduino.h>
#include "LidarHelper.h" // Include the LiDAR helper file
#include "WifiHelper.h"
#include "SensorHelper.h"
// Start the serial communication:
Serial2.begin(230400, SERIAL_8N1, 16, 17); // Baud rate and UART2 pins lidar
sensors.begin();
pinMode(flowPin, INPUT_PULLUP); // water flow pin Set flow sensor pin as input
pinMode(relayPin, OUTPUT); // Set the relay pin as an output for lidar
pinMode(hunterPin, OUTPUT); // Set relay pin as output
pinMode(digitalPin, INPUT); // water drop sensor
pinMode(analogPin, INPUT); // Set analog pin as input
// checkDeviceIP();
attachInterrupt(digitalPinToInterrupt(flowPin), pulseCounter, RISING); // Interrupt on rising edge
flowMillis = millis();
// Connect to Wi-Fi
setupAccessPointAndServer();
digitalWrite(relayPin, LOW); // Start with the relay off
server.handleClient();
handleLidarData();
waterFlowSensor();
static unsigned long lastReadingTime = 0;
// if (millis() - lastReadingTime >= 5000) {
tempSensor(); // Get temperature reading
// lastReadingTime = millis();
//if (millis() - lastReadingTime >= 5000) {
waterDropSensor(); // Add this line to call the water drop sensor function
if (delayRunning && (millis() - delayStart >= 100000)) {
delayRunning = false;
// Delay has finished, perform any actions that should happen after the delay
if (WiFi.status() == WL_CONNECTED) {
WiFi.softAPdisconnect(true);
Serial.println("Access Point Stopped");
// delay(1000);
// WifiHelper.h
#ifndef WIFI_HELPER_H
#define WIFI_HELPER_H
#define BLYNK_TEMPLATE_ID "TMPL2MJ_30SAi"
#define BLYNK_TEMPLATE_NAME "ESP32Sensor"
#define BLYNK_AUTH_TOKEN "ZPd901JgdiSGUOP7HMna9V9tRRMKcboD"
// #define BLYNK_FIRMWARE_VERSION "0.1.0"
#define APP_DEBUG
#include <WiFi.h>
#include <WebServer.h>
#include <Preferences.h>
#include <WiFiUdp.h>
#include <AsyncUDP.h>
#include <BlynkSimpleEsp32.h>
Preferences preferences;
//const char* globalSSID = "The LAN before Time"; // Replace with your network SSID
//const char* globalPassword = "Jbl?8042"; // Replace with your network password
const char* SSID = "lidar"; // Replace with your network SSID
const char* Password = "123456789"; // Replace with your network password
bool relayState = false; // Variable to hold the relay state
const int relayPin = 13; // Relay connected to GPIO 13
// String state = "";
// WiFiUDP udp;
//AsyncUDP udp;
LidarPacket latestPacket;
//WebServer server(80);
bool isConnected = false; // Flag to check connection status
uint8_t globalByte;
String lidarDataBuffer = "";
String ipAddressStr = "";
//IPAddress ipAddress; // For storing the converted IP address
String ssidBlynk = "";
String passwordBlynk = "";
unsigned long delayStart = 0;
bool delayRunning = false;
const int SOME_MAX_SIZE = 46 * 2; // 7200 bytes * 2 characters per byte
//const int PACKET_SIZE = sizeof(LidarPacket);
//unsigned int udpPort = 8042; // Example port number
const char* data = "Hello, UDP!";
char incomingPacket[255]; // Buffer for incoming packets
const int rele = 23;
int stateNum = 0; // 0 = undefined, 1 = on, 2 = off
void handleRelayToggle() {
if (server.hasArg("state")) {
state = server.arg("state");
if (state == "on") {
digitalWrite(relayPin, HIGH); // Turn on the relay
stateNum = 1;
} else if (state == "off") {
digitalWrite(relayPin, LOW); // Turn off the relay
stateNum = 2;
server.send(200, "text/plain", "Relay state set to " + state);
Serial.println("State is set to " + state);
Blynk.virtualWrite(V3, stateNum); // Send flowRate to virtual pin V1
server.send(400, "text/plain", "Missing 'state' parameter");
// Blynk handler to receive commands from the Blynk app
BLYNK_WRITE(V3) {
stateNum = param.asInt(); // Get the state number (1 for on, 2 for off)
if (stateNum == 1) {
Serial.println("Relay turned ON via Blynk");
} else if (stateNum == 2) {
Serial.println("Relay turned OFF via Blynk");
void handleReceiveIP() {
if (server.hasArg("ip")) {
ipAddressStr = server.arg("ip");
if (ipAddress.fromString(ipAddressStr)) { // Convert String to IPAddress
Serial.println("Received and converted IP: " + ipAddressStr);
// Now, you can use ipAddress with udp.begin
//Serial.println("UDP server started");
server.send(200, "text/plain", "IP Address received and UDP started: " + ipAddressStr);
Serial.println("Invalid IP address received");
server.send(400, "text/plain", "Invalid IP address");
server.send(400, "text/plain", "Missing IP address");
void handleRoot() {
server.send(200, "text/plain", "\n ESP32 is connected to Wi-Fi.");
// Function to handle removal of Wi-Fi configuration
bool removeWiFiConfiguration() {
preferences.begin("wifi", false);
preferences.remove("homeSSID");
preferences.remove("homePassword");
preferences.remove("cellularSSID");
preferences.remove("cellularPassword");
preferences.end();
return true; // Return true if successful, otherwise handle failure as needed
void handleRemoveWiFi() {
if (server.hasArg("action")) {
String action = server.arg("action");
if (action == "remove_wifi") {
if (removeWiFiConfiguration()) {
Serial.println("Wifi Configuration moved");
server.send(200, "text/plain", "Wi-Fi configuration removed");
server.send(500, "text/plain", "Failed to remove Wi-Fi configuration");
server.send(400, "text/plain", "Invalid action");
server.send(400, "text/plain", "Missing action parameter");
bool connectToWiFi(String ssid, String password) {
if (ssid.isEmpty() || password.isEmpty()) {
Serial.println("Missing SSID or Password in the request");
server.send(400, "text/plain", "Missing SSID or Password");
return false;
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Optional: Static IP configuration
IPAddress staticIP(WiFi.localIP()); // Use the current local IP (if any)
IPAddress gateway(WiFi.gatewayIP()); // Gateway (your router IP)
IPAddress subnet(WiFi.subnetMask()); // Subnet mask
IPAddress primaryDNS(1, 1, 1, 1); // Cloudflare Primary DNS
IPAddress secondaryDNS(1, 0, 0, 1); // Cloudflare Secondary DNS
// Only configure static IP if the current IP is valid
if (staticIP != IPAddress(0, 0, 0, 0) && !WiFi.config(staticIP, gateway, subnet,primaryDNS,secondaryDNS)) {
Serial.println("STA Failed to configure static IP");
// Attempt to connect to the new Wi-Fi network
WiFi.begin(ssid.c_str(), password.c_str());
unsigned long startTime = millis();
delay(500);
Serial.print(".");
if (millis() - startTime > 30000) { // 30-second timeout
Serial.println("\nFailed to connect to Wi-Fi.");
server.send(500, "text/plain", "Failed to connect to Wi-Fi");
return false;
Serial.println("\nConnected to Wi-Fi!");
Serial.println("\nConnected to Blynk!");
Serial.print("IP Address: ");
// Disconnect from the SoftAP
Serial.println("SoftAP disconnected.");
passwordBlynk = password;
ssidBlynk = ssid;
// Send a successful response
server.send(200, "text/plain", "Connected to new Wi-Fi successfully");
return true;
void setupAccessPointAndServer() {
Preferences preferences; // Create a Preferences object
preferences.begin("wifi", false); // Open the NVS namespace "wifi"
// Retrieve Wi-Fi configurations from NVS
String homeSSID = preferences.getString("homeSSID", "");
String homePassword = preferences.getString("homePassword", "");
String cellularSSID = preferences.getString("cellularSSID", "");
String cellularPassword = preferences.getString("cellularPassword", "");
// Start ESP32 as an Access Point
WiFi.softAP(SSID, Password);
Serial.println("Access Point Started");
Serial.println("AP IP Address: ");
Serial.println(WiFi.softAPIP());
// Try connecting to home Wi-Fi first, then cellular network
if (!connectToWiFi(homeSSID, homePassword)) {
Serial.println("Failed to connect to home Wi-Fi, trying cellular...");
if (!connectToWiFi(cellularSSID, cellularPassword)) {
Serial.println("Failed to connect to both home and cellular Wi-Fi");
// Setup server routes
server.on("/setup", HTTP_POST, [&]() {
Serial.println("Received a request on /setup");
// Get SSIDs and passwords from the request
String newHomeSSID = server.arg("homeSSID");
String newHomePassword = server.arg("homePassword");
String newCellularSSID = server.arg("cellularSSID");
String newCellularPassword = server.arg("cellularPassword");
// Save SSIDs and passwords to NVS
if (!newHomeSSID.isEmpty() && !newHomePassword.isEmpty()) {
preferences.putString("homeSSID", newHomeSSID);
preferences.putString("homePassword", newHomePassword);
Serial.println("New Home SSID and Password saved");
if (!newCellularSSID.isEmpty() && !newCellularPassword.isEmpty()) {
preferences.putString("cellularSSID", newCellularSSID);
preferences.putString("cellularPassword", newCellularPassword);
Serial.println("New Cellular SSID and Password saved");
server.send(200, "text/plain", "Wi-Fi configuration saved");
// Attempt to reconnect with the new credentials
if (!connectToWiFi(newHomeSSID, newHomePassword)) {
if (!connectToWiFi(newCellularSSID, newCellularPassword)) {
server.send(500, "text/plain", "Failed to connect to new Wi-Fi");
server.on("/getIP", HTTP_GET, []() {
server.send(200, "text/plain", WiFi.localIP().toString());
Blynk.begin(BLYNK_AUTH_TOKEN, ssidBlynk.c_str(), passwordBlynk.c_str(), "blynk-cloud.com", 8080);
Serial.println("Send localIP to swift");
server.send(404, "text/plain", "Not connected to WiFi");
server.on("/receiveIP", HTTP_GET, handleReceiveIP);
server.on("/wifiConnected", handleRoot);
preferences.end(); // Close the NVS namespace
server.on("/toggleRelay", HTTP_GET, handleRelayToggle);
server.on("/toggleValve", HTTP_GET, handleToggleValve);
server.on("/flowrate", HTTP_GET, handleFlowRate); // Endpoint to get the flow rate
server.on("/waterdrops", HTTP_GET, handleWaterDropSensor);
server.on("/temp", HTTP_GET, tempSensor);
server.on("/remove_wifi", HTTP_POST, handleRemoveWiFi);
server.begin();
// Blynk.config(BLYNK_AUTH_TOKEN, "blynk-cloud.com", 80); // Explicitly set the server
// Blynk.connect();
server.send(200, "text/plain", "ESP32 setup Successfull");
//delay(100000);
//isConnected = true;
// WiFi.softAPdisconnect(true);
//Serial.println("Access Point Stopped");
//delayStart = millis();
//delayRunning = true;
#endif
