I’m working on a project that requires daily analysis of gases and air quality in a room. I’m using an ESP32 WROOM 32D development board along with MQ9, MQ135, and DHT22 sensors. I’m encountering some connection issues with Blynk. After turning the device on, it disconnects from Blynk within a few minutes. Here’s the code for reference:
#define BLYNK_TEMPLATE_ID "XXXXX"
#define BLYNK_AUTH_TOKEN "XXXXX"
#define BLYNK_TEMPLATE_NAME "XXXXX"
#include <Adafruit_GFX.h>
#include <Adafruit_ST7789.h>
#include <DHT.h>
#include <WiFi.h>
#include <BlynkSimpleEsp32.h>
#define ST77XX_GREEN 0x07E0
#define ST77XX_YELLOW 0xFFE0
#define ST77XX_ORANGE 0xFD20
#define ST77XX_RED 0xF800
#define ST77XX_PURPLE 0x780F
#define ST77XX_MAROON 0x7800
#define ST77XX_WHITE 0xFFFF
#define ST77XX_BLUE 0x001F
#define ST77XX_BLACK 0x0000
#define TFT_CS 5
#define TFT_RST 4
#define TFT_DC 2
#define MQ135_PIN 34
#define MQ9_PIN 35
#define DHTPIN 32
#define DHTTYPE DHT22
char auth[ ] = "XXXXX";
char ssid[] = "XXXXX";
char pass[] = "XXXXX";
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
DHT dht(DHTPIN, DHTTYPE);
unsigned long lastReconnectAttempt = 0;
int reconnectInterval = 10000;
int gasesMQ135[7];
int gasesMQ9[4];
tft.init(135, 240);
tft.fillScreen(ST77XX_BLUE);
dht.begin();
connectToWifi();
Blynk.config(auth);
Blynk.connect();
timer.setInterval(5000L, readSensors);
timer.setInterval(6000L, sendToBlynk);
Serial.println("Setup complete. Sensors warming up...");
void connectToWifi() {
WiFi.begin(ssid, pass);
int attempts = 0;
while (WiFi.status() != WL_CONNECTED && attempts < 30) {
delay(500); // Short delay to avoid spamming connection attempts
Serial.print(".");
attempts++;
if (WiFi.status() == WL_CONNECTED) {
Serial.println("\nConnected to WiFi");
Serial.println("\nFailed to connect to WiFi");
float convertToPPm(int raw, int gasType) {
switch (gasType) {
case 0:
return raw * (1000.0 / 4095.0);
case 1:
return raw * (10000.0 / 4095.0);
case 2:
case 3:
case 4:
return raw * (10.0 / 4095.0);
case 5:
default:
return raw / 10.0;
int calculateAQI(float concentration, float concLow, float concHigh, int indexLow, int indexHigh) {
if (concentration < concLow) concentration = concLow;
return ((indexHigh - indexLow) / (concHigh - concLow)) * (concentration - concLow) + indexLow;
int getAQI() {
float CO_ppm = convertToPPm(gasesMQ9[0], 0);
float NO2_ppm = convertToPPm(gasesMQ135[3], 4);
float O3_ppm = convertToPPm(gasesMQ135[4], 5);
Serial.print("CO ppm: ");
Serial.println(CO_ppm);
Serial.print("NO2 ppm: ");
Serial.println(NO2_ppm);
Serial.print("O3 ppm: ");
Serial.println(O3_ppm);
int AQI_CO = calculateAQI(CO_ppm, 0.0, 50.0, 0, 50);
int AQI_NO2 = calculateAQI(NO2_ppm, 0.0, 1.0, 0, 200);
int AQI_O3 = calculateAQI(O3_ppm, 0.0, 1.0, 0, 200);
int AQI = max(max(AQI_CO, AQI_NO2), AQI_O3);
Serial.print("AQI_CO: ");
Serial.println(AQI_CO);
Serial.print("AQI_NO2: ");
Serial.println(AQI_NO2);
Serial.print("AQI_O3: ");
Serial.println(AQI_O3);
Serial.print("Max AQI: ");
Serial.println(AQI);
return AQI;
void displayAQI(int AQI) {
uint16_t bgColor;
uint16_t textColor = ST77XX_WHITE;
String aqiText;
if (AQI <= 50) {
bgColor = ST77XX_GREEN;
aqiText = "Good";
} else if (AQI <= 100) {
bgColor = ST77XX_YELLOW;
aqiText = "Moderate";
textColor = ST77XX_BLACK;
} else if (AQI <= 150) {
bgColor = ST77XX_ORANGE;
aqiText = "Unhealthy for Sensitive Groups";
} else if (AQI <= 200) {
bgColor = ST77XX_RED;
aqiText = "Unhealthy";
} else if (AQI <= 300) {
bgColor = ST77XX_PURPLE;
aqiText = "Very Unhealthy";
bgColor = ST77XX_MAROON;
aqiText = "Hazardous";
tft.fillRect(0, 190, 135, 60, bgColor);
tft.setCursor(0, 200);
tft.setTextColor(textColor);
tft.setTextSize(1);
tft.println("AQI: " + String(AQI));
tft.setCursor(0, 210);
tft.println(aqiText);
void displaySensorData() {
tft.fillRect(0, 0, 135, 200, ST77XX_BLUE);
tft.setTextColor(ST77XX_WHITE);
tft.setTextSize(1);
int y = 0;
tft.setCursor(0, y);
tft.println("*Benzene: " + String(convertToPPm(gasesMQ135[0], 0)) + " ppm");
y += 10;
tft.println("*Toluene: " + String(convertToPPm(gasesMQ135[5], 0)) + " ppm");
y += 10;
tft.println("*Xylenes: " + String(convertToPPm(gasesMQ135[6], 0)) + " ppm");
y += 10;
tft.println("*Formaldehyde: " + String(convertToPPm(gasesMQ135[1], 0)) + " ppm");
y += 10;
tft.println("---------------------");
y += 10;
tft.println("CO: " + String(convertToPPm(gasesMQ9[0], 0)) + " ppm");
y += 10;
tft.println("Ammonia: " + String(convertToPPm(gasesMQ135[2], 0)) + " ppm");
y += 10;
tft.println("NO2: " + String(convertToPPm(gasesMQ135[3], 4)) + " ppm");
y += 17;
tft.println("Ozone: " + String(convertToPPm(gasesMQ135[4], 5)) + " ppm");
y += 10;
tft.println("Methane: " + String(convertToPPm(gasesMQ9[1], 1)) + " ppm");
y += 10;
tft.println("LPG: " + String(convertToPPm(gasesMQ9[2], 2)) + " ppm");
y += 17;
tft.println("Hydrogen: " + String(convertToPPm(gasesMQ9[3], 3)) + " ppm");
y += 10;
tft.println("CO2: " + String(convertToPPm(gasesMQ135[4], 5)) + " ppm"); CO2 reading from MQ135
y += 10;
tft.println("Nitric Oxide: " + String(convertToPPm(gasesMQ135[3], 4)) + " ppm");
y += 10;
float temp = dht.readTemperature();
float humidity = dht.readHumidity();
y += 13;
tft.println("Temp: " + String(temp) + " C");
y += 10;
tft.println("Humidity: " + String(humidity) + "%");
y += 20;
int AQI = getAQI();
displayAQI(AQI);
void readSensors() {
int rawMQ135 = analogRead(MQ135_PIN);
int rawMQ9 = analogRead(MQ9_PIN);
Serial.print("Raw MQ135: ");
Serial.println(rawMQ135);
Serial.print("Raw MQ9: ");
Serial.println(rawMQ9);
for (int i = 0; i < 7; i++) {
gasesMQ135[i] = rawMQ135 / (i + 1);
for (int j = 0; j < 4; j++) {
gasesMQ9[j] = rawMQ9 / (j + 1);
displaySensorData();
> Blockquote
void sendToBlynk() {
Blynk.virtualWrite(V0, convertToPPm(gasesMQ135[0], 0));
Blynk.virtualWrite(V1, convertToPPm(gasesMQ9[0], 0));
Blynk.virtualWrite(V2, convertToPPm(gasesMQ135[1], 0));
Blynk.virtualWrite(V3, convertToPPm(gasesMQ135[2], 0));
Blynk.virtualWrite(V4, convertToPPm(gasesMQ135[3], 4));
Blynk.virtualWrite(V5, convertToPPm(gasesMQ135[4], 5));
Blynk.virtualWrite(V6, convertToPPm(gasesMQ135[5], 0));
Blynk.virtualWrite(V7, convertToPPm(gasesMQ135[6], 0));
Blynk.virtualWrite(V8, convertToPPm(gasesMQ9[1], 1));
Blynk.virtualWrite(V9, convertToPPm(gasesMQ9[2], 2));
Blynk.virtualWrite(V10, convertToPPm(gasesMQ9[3], 3));
Blynk.virtualWrite(V11, convertToPPm(gasesMQ135[4], 5));
Blynk.virtualWrite(V12, convertToPPm(gasesMQ135[3], 4));
Blynk.virtualWrite(V13, dht.readTemperature());
Blynk.virtualWrite(V14, dht.readHumidity());
Blynk.virtualWrite(V15, getAQI());
Blynk.run(); // Allow Blynk to process events
if (WiFi.status() != WL_CONNECTED) {
connectToWifi();
timer.run(); // Run the Blynk timer
