void Sync()
CH1Period = CH1End - CH1Start;
CH2Period = CH2End - CH2Start;
CH3Period = CH3End - CH3Start;
CH4Period = CH4End - CH4Start;
CH5Period = CH5End - CH5Start;
CH6Period = CH6End - CH6Start;
//CHANNEL 2/////////////////////////////////////////////////////////////////////
BLYNK_WRITE(V8) //Start time
CH2S = param.asInt();
Blynk.virtualWrite(V8, CH2S);
CH2Start = CH2S*60;
////EEPROM.put(25, CH2Start);
////EEPROM.commit();
BLYNK_WRITE(V9) //End time
CH2E = param.asInt();
Blynk.virtualWrite(V9, CH2E);
CH2End = CH2E*60;
////EEPROM.put(30, CH2End);
BLYNK_WRITE(V10) //FadeIn time
FadeINmin2 = param.asInt();
Blynk.virtualWrite(V10, FadeINmin2);
FadeINsecs2 = FadeINmin2*60;
////EEPROM.put(35, FadeINsecs2);
BLYNK_WRITE(V11) //FadeOut time
FadeOUTmin2 = param.asInt();
Blynk.virtualWrite(V11, FadeOUTmin2);
FadeOUTsecs2 = FadeOUTmin2*60;
////EEPROM.put(40, FadeOUTsecs2);
BLYNK_WRITE(V12) //Intensity value
maxPWM2 = param.asInt();
Blynk.virtualWrite(V12, maxPWM2);
BLYNK_WRITE(V56) //Saved Intensity value
svPWM2 = param.asInt();
Blynk.virtualWrite(V56, svPWM2);
////EEPROM.put(45, svsvPWM2);
BLYNK_READ(V39)
Blynk.virtualWrite(V39, C2prog);
//CHANNEL 3/////////////////////////////////////////////////////////////////////
BLYNK_WRITE(V14) //Start time
CH3S = param.asInt();
Blynk.virtualWrite(V14, CH3S);
CH3Start = CH3S*60;
////EEPROM.put(50, CH3Start);
BLYNK_WRITE(V15) //End time
CH3E = param.asInt();
Blynk.virtualWrite(V15, CH3E);
CH3End = CH3E*60;
////EEPROM.put(55, CH3End);
BLYNK_WRITE(V16) //FadeIn time
FadeINmin3 = param.asInt();
Blynk.virtualWrite(V16, FadeINmin3);
FadeINsecs3 = FadeINmin3*60;
////EEPROM.put(60, FadeINsecs3);
BLYNK_WRITE(V17) //FadeOut time
FadeOUTmin3 = param.asInt();
Blynk.virtualWrite(V17, FadeOUTmin3);
FadeOUTsecs3 = FadeOUTmin3*60;
////EEPROM.put(65, FadeOUTsecs3);
BLYNK_WRITE(V18) //Intensity value
maxPWM3 = param.asInt();
Blynk.virtualWrite(V18, maxPWM3);
BLYNK_WRITE(V57) //Saved Intensity value
svPWM3 = param.asInt();
Blynk.virtualWrite(V57, svPWM3);
////EEPROM.put(70, PWM3);
BLYNK_READ(V40)
Blynk.virtualWrite(V40, C3prog);
//CHANNEL 4/////////////////////////////////////////////////////////////////////
BLYNK_WRITE(V20) //Start time
CH4S = param.asInt();
Blynk.virtualWrite(V20, CH4S);
CH4Start = CH4S*60;
////EEPROM.put(75, CH4Start);
BLYNK_WRITE(V21) //End time
CH4E = param.asInt();
Blynk.virtualWrite(V21, CH4E);
CH4End = CH4E*60;
////EEPROM.put(80, CH4End);
BLYNK_WRITE(V22) //FadeIn time
FadeINmin4 = param.asInt();
Blynk.virtualWrite(V22, FadeINmin4);
FadeINsecs4 = FadeINmin4*60;
////EEPROM.put(85, FadeINsecs4);
//EEPROM.commit();
BLYNK_WRITE(V23) //FadeOut time
FadeOUTmin4 = param.asInt();
Blynk.virtualWrite(V23, FadeOUTmin4);
FadeOUTsecs4 = FadeOUTmin4*60;
//EEPROM.put(90, FadeOUTsecs4);
//EEPROM.commit();
BLYNK_WRITE(V24) //Intensity value
maxPWM4 = param.asInt();
Blynk.virtualWrite(V24, maxPWM4);
BLYNK_WRITE(V58) //Saved Intensity value
svPWM4 = param.asInt();
Blynk.virtualWrite(V58, svPWM4);
//EEPROM.put(95, PWM4);
//EEPROM.commit();
BLYNK_READ(V41)
Blynk.virtualWrite(V41, C4prog);
This my code for my 8 channel Led lighting. Try to use Blynk only as a method to get the info and write your code in a way that the lighting can run without the need to keep referring back to Blynk. The reason if the internet drops the lighting schedule will continue as normal. Hope this helps.
