Esp32 wifi & sim800
Hi ! ( salut )
I use a WROOM32 with WIFI and the SIM800 as a backup if there is no more WIFI connection.
What is the best way to do it?
I tried :
Blynk.begin (auth, ipWan, port);
but the compiler does not want it
the :
#include <Blynk.h>
not enough ?
thank you in advance
We need to see your complete code.
thx
here we go :
for WIFI :
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char pass[] = "YourPassword";
char ipWan[] = "my.ip.wan.server";
uint16_t port = 8080;
byte test1;
Blynk.begin(auth, ssid, pass, my.ip.wan.server,port);
  Blynk.virtualWrite(V5, test1);
  test1++;
and for sim
#define TINY_GSM_MODEM_SIM800
#include <TinyGsmClient.h>
#include <BlynkSimpleSIM800.h>
SoftwareSerial SerialAT(2,3);
TinyGsm modem(SerialAT);
char apn[]  = "apn";
char user[] = "user";
char pass[] = "pass";
char ipWan[] = "my.ip.wan.server";;
  SerialAT.begin(9600);
  delay(3000);
  Blynk.begin(auth, modem, apn,user, pass,ipWan, port);
  test1++;
it works very well separately
Well, to begin with, having this in your void loop breaks the number 1 rule of Blynk…
Secondly, you need to explain more about what your combined code looks like, what specifically your compiler errors are, and maybe explain the logic of how your combined code is choosing which connection method to use.
Also, you might want to take a look at this library…
