Hi everyone!
I’ve use a Quickstart guide, have succses ping to blynk.cloud from my ESP32 Dev Module with WiFi,
but my board doesn’t connect on web version blynk.cloud.
I’ve use Arduino IDE 1.8.19, Blynk Library 1.0.1
Here is an example:
#define BLYNK_TEMPLATE_ID "TMPLV78xHIYT"
#define BLYNK_DEVICE_NAME "Quickstart Device"
#define BLYNK_AUTH_TOKEN "C---------------------------------e"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char ssid[] = "Ses";
char pass[] = "12345678";
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
// Set incoming value from pin V0 to a variable
int value = param.asInt();
// Update state
Blynk.virtualWrite(V1, value);
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
// Change Web Link Button message to "Congratulations!"
Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
Blynk.setProperty(V3, "onImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
Blynk.virtualWrite(V2, millis() / 1000);
Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
// to avoid delay() function!
As you can see, board have a ping to blynk.cloud:80
[18752] Connecting to blynk.cloud:80
[19382] Ready (ping: 305ms).
ets Jun 8 2016 00:22:57
rst:0x10 (RTCWDT_RTC_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13864
load:0x40080400,len:3608
entry 0x400805f0
[34] Connecting to Ses
[1655] Connected to WiFi
[1655] IP: 172.20.10.12
[1655]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.4.8 on ESP32
[5001] Connecting to blynk.cloud:80
[5724] Ready (ping: 305ms).
[11442] Connecting to blynk.cloud:80
[12192] Ready (ping: 316ms).
[17791] Connecting to blynk.cloud:80
[18421] Ready (ping: 305ms).
[24037] Connecting to blynk.cloud:80
[25077] Ready (ping: 305ms).
[30899] Connecting to blynk.cloud:80
[31528] Ready (ping: 305ms).
But doesn’t connect to Console!
Also been used VPN connecion. Doesn’t help…
Thank you!
Thank you very much!
