Hi
I using blynk legacy for my project. My project is esp32 control 2 channel 5V relay module on off via 2 mode (switch button dan blynk app)
My problem is, after turn on power for esp32, switch button dont work unless esp32 connect to wifi first.
My second problem is, here at my place wifi connect is unstable. Esp32 wont reconnect to same wifi if disconnect. I nned to turn off and turn on back power if i want esp32 to connect to wifi.
Here is my code
#define BLYNK_AUTH_TOKEN "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
//server status led
#define BlynkLED 2
//buttons and led pins
#define btn1 26
#define btn2 27
#define relay1 18
#define relay2 19
//led states
bool relay1State = false;
bool relay2State = false;
//server state | flag for online/Offline Mode
bool onlineMode = false;
//Wifi config
char ssid[] = "XXXXXXXXXX"; //nama wifi
char pass[] = "XXXXXXXXXX"; //password wifi
bool ledStatus = false;
WidgetLED led1(V8);
#define BLYNK_GREEN "#23C48E"
#define BLYNK_BLUE "#04C0F8"
#define BLYNK_YELLOW "#ED9D00"
#define BLYNK_RED "#D3435C"
#define BLYNK_DARK_BLUE "#5F7CD8"
timer.setInterval(2000L, isServerConnected);
pinMode(BlynkLED, OUTPUT);
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(btn1, INPUT_PULLUP);
pinMode(btn2, INPUT_PULLUP);
Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass, IPAddress(XXX, XXX, XXX, XXX), XXXX);
Blynk.virtualWrite(V1, LOW);
Blynk.virtualWrite(V2, LOW);
led1.on();
//Blynk.run();
if (onlineMode) {
whenOnline(); //handles online functionalities
whenOffline(); //handles offline functionalities
void whenOnline() {
if (digitalRead(btn1) == LOW) {
relay1State = !relay1State;
updateLEDs();
delay(50);
while (digitalRead(btn1) == LOW);
updateBlynkServer();
if (digitalRead(btn2) == LOW) {
relay2State = !relay2State;
updateLEDs();
delay(50);
while (digitalRead(btn2) == LOW);
void whenOffline() {
updateLEDs();
delay(50);
updateLEDs();
delay(50);
void updateLEDs() {
digitalWrite(relay1, relay1State);
digitalWrite(relay2, relay2State);
void updateBlynkServer() {
Blynk.virtualWrite(V1, relay1State);
Blynk.virtualWrite(V2, relay2State);
BLYNK_WRITE(V1) {
relay1State = param.asInt();
Serial.println(relay1State);
updateLEDs();
BLYNK_WRITE(V2) {
relay2State = param.asInt();
Serial.println(relay2State);
updateLEDs();
void isServerConnected() {
bool isConnected = Blynk.connected();
if (isConnected == true) {
onlineMode = true;
digitalWrite(BlynkLED, HIGH);
Serial.println("Connected");
if (isConnected == false) {
if (onlineMode == true) {
onlineMode = false;
Serial.println("Not Connected");
digitalWrite(BlynkLED, LOW);
void blinkLedWidget()
if (ledStatus) {
led1.setColor(BLYNK_YELLOW);
Serial.println("LED on V8: yellow");
ledStatus = false;
led1.setColor(BLYNK_BLUE);
Serial.println("LED on V8: blue");
ledStatus = true;
