hardware Model and Communication Type:
#Board: Lilygo with ESP32 + SIMCOM7600G-H 4G Module
#Smartphone OS:
#Tested on: Android and iOS
#Blynk Library Version: Version : 1.3.2
Issue Description:
I have an ESP32 project using a SIMCOM7600G-H 4G module to send DHT sensor data to the Blynk cloud every minute. This setup works perfectly under normal conditions. However, when I use a trigger from the Blynk app to make a call, the GSM SIM7600G-H module does not support concurrency. As a result, the call connects, but the internet gets disconnected, leading to a Blynk disconnection.
After the call ends, Blynk shows a debug message indicating it’s reconnecting, but it never successfully reconnects to the network. Here’s what I’ve tried so far:
- Calling
blynk.connect()after disconnection: This did not work. - Re-initializing or restarting the GSM module: Not sure if this is needed or how to properly implement it.
- Handling GSM Band Reconnection: Suspect that the SIMCOM module might switch network bands during the call, causing issues with reconnecting to the internet band that Blynk/TinyGSM library does not handle automatically.
Possible Solutions:
- Do I need to fully reinitialize the GSM module after a call ends?
- Is there a need to reset the network band to ensure a smooth reconnection?
Request for Help:
I would appreciate any pseudo-code or guidance on how to handle GSM module reconnection properly with Blynk after a call.
#include <TinyGsmClient.h>
#include <DHT.h>
#define TINY_GSM_MODEM_SIM7600
// Set serial for debug console
#define SerialMon Serial
#define SerialAT Serial1
// Your Blynk credentials
char apn[] = "YourAPN";
char user[] = "";
char pass[] = "";
// DHT sensor setup
#define DHTPIN 4
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
// TinyGSM and Blynk setup
TinyGsm modem(SerialAT);
SerialMon.begin(115200);
// Start communication with GSM module
SerialAT.begin(9600);
delay(3000);
// Restart and initialize the modem
modem.restart();
modem.gprsConnect(apn, user, pass);
// Initialize Blynk
// Setup a timer to send sensor data
timer.setInterval(60000L, sendSensorData);
void sendSensorData() {
float h = dht.readHumidity();
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
BLYNK_WRITE(V1) {
// Trigger a GSM call
String number = param.asStr();
modem.callNumber(number.c_str());
What Happens:
- Normal Operation : Sensor data sent every minute.
- GSM Call Triggered : Internet disconnects, call proceeds.
- After Call Ends : Blynk shows reconnecting message but fails to reconnect.
Needed:
Pseudo-code or steps to properly handle GSM module reconnection and Blynk re-initialization after the call ends.
Thank you in advance for your assistance!
