I would like to make a thermometer that will show values through the application but for some reason still shows 0.
but when i try through the SHT31 example it works. does anyone know where the bug is?
thank you
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <SHT3x.h>
SHT3x Sensor;
char auth[] = "1489938d543349cf873c5487323c74d2";
char ssid[] = "NETGEAR41";
char pass[] = "rapidapple717";
void sendSensor()
float h = Sensor.GetTemperature();
float t = Sensor.GetRelHumidity(); // or dht.readTemperature(true) for Fahrenheit
Serial.println(h,t);
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
Sensor.Begin();
Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,118), 8080);
