ESP32 DHT11/DHT22 Asynchronous Web Server (auto updates Temperature and Humidity) with led that It turns on when we click on a button in the application
I connet the output pin in the sensor with pin27 and (-) with ground and (+) with vcc (5volt)
And I connect the led with resistance
I connect the resistancewith ground and output(pin22)
And all of them connect with esp32
When I compile the code it’s success but when I upload it and when show in webserverit give me this problem
My cood :
#include "WiFi.h"
#include "ESPAsyncWebServer.h"
#include <Adafruit_Sensor.h>
#include <DHT.h>
#define DHTPIN 27 // Digital pin connected to the DHT sensor
DHT dht(DHTPIN, DHTTYPE);
const char* ssid= "Anwar2";
const char* password = "12345678";
WiFiServer server(80);
String header;
String LED_ONE_STATE = "off";
const int GPIO_PIN_NUMBER_22 = 22;
String readDHTTemperature() {
if (isnan(t)) {
Serial.println("Failed to read from DHT sensor!"); //We also have a condition that returns two dashes (–) in case the sensor fails to get the readings
return "--";
else {
Serial.println(t);
return String(t); //The readings are returned as string type. To convert a float to a string, use the String() function.
String readDHTHumidity() {
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
if (isnan(h)) {
return "--";
else {
Serial.println(h);
return String(h);
const char index_html[] PROGMEM = R"rawliteral(
WiFiClient client = server.available();
if (client) {
Serial.println("New Client is requesting web page");
String current_data_line = "";
while (client.connected()) {
if (client.available()) {
char new_byte = client.read();
Serial.write(new_byte);
header += new_byte;
if (new_byte == '\n') {
if (current_data_line.length() == 0)
client.println("HTTP/1.1 200 OK");
client.println("Content-type:text/html");
client.println("Connection: close");
client.println();
if (header.indexOf("LED0=ON") != -1)
Serial.println("GPIO23 LED is ON");
LED_ONE_STATE = "on";
digitalWrite(GPIO_PIN_NUMBER_22 , HIGH);
if (header.indexOf("LED0=OFF") != -1)
Serial.println("GPIO23 LED is OFF");
digitalWrite(GPIO_PIN_NUMBER_22, LOW);
client.println("<!DOCTYPE html><html>");
client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
client.println("<link rel=\"icon\" href=\"data:,\">");
client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
client.println(".button { background-color: #4CAF50; border: 2px solid #4CAF50;; color: white; padding: 15px 32px; text-align: center; text-decoration: none; display: inline-block; font-size: 16px; margin: 4px 2px; cursor: pointer; }");
client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
// Web Page Heading
client.println("</style></head>");
client.println("<body><center><h1>ESP32 Web server LED controlling example</h1></center>");
client.println("<center><h2>Web Server Example Microcontrollerslab.com</h2></center>" );
client.println("<center><h2>Press on button to turn on led and off button to turn off LED</h3></center>");
client.println("<form><center>");
client.println("<p> LED one is " + LED_ONE_STATE + "</p>");
// If the PIN_NUMBER_22State is off, it displays the ON button
client.println("<center> <button class=\"button\" name=\"LED0\" value=\"ON\" type=\"submit\">LED0 Off</button>") ;
client.println("<button class=\"button\" name=\"LED0\" value=\"OFF\" type=\"submit\">LED0 ON</button><br><br>");
client.println("</center></form></body></html>");
client.println();
else if (new_byte != '\r')
current_data_line += new_byte;
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("Client disconnected.");
Serial.println("");
<script>
setInterval(function ( ) {
var xhttp = new XMLHttpRequest();
xhttp.onreadystatechange = function() {
if (this.readyState == 4 && this.status == 200) {
document.getElementById("temperature").innerHTML = this.responseText;
xhttp.open("GET", "/temperature", true);
xhttp.send();
}, 10000 ) ;//that updates the temperature and humidity automatically, every 10 seconds.
setInterval(function ( ) {//To update the temperature on the background, we have a setInterval() function that runs every 10 seconds.
document.getElementById("humidity").innerHTML = this.responseText;
xhttp.open("GET", "/humidity", true);
xhttp.send();
}, 10000 ) ;
</script>}}
</html>)rawliteral";
String processor(const String& var){
//Serial.println(var);
if(var == "TEMPERATURE"){
return readDHTTemperature();
else if(var == "HUMIDITY"){
return readDHTHumidity();
return String();
AsyncWebServer server(80);
pinMode(GPIO_PIN_NUMBER_22, OUTPUT);
digitalWrite(GPIO_PIN_NUMBER_22, HIGH);
dht.begin();
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi..");
// Route for root / web page
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/html", index_html, processor);
server.on("/temperature", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", readDHTTemperature().c_str());
server.on("/humidity", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", readDHTHumidity().c_str());
Serial.println("");
server.begin();
void loop(){
